PM for a 500 Mile Round Trip
   / PM for a 500 Mile Round Trip
interesting project. This oughta keep you busy for awhile and out of trouble.;)
in the last picture you posted, I am concerned seeing a crack that large in the frame. Can you elaborate on that crack, any plans to fix it ?
The crack had been completely covered by the truck (as I now know it's called). When I saw it after I had the trailer taken apart, I about had a heart attack. On closer inspection, however, I saw that the back side of the crack has been welded, and there's a strap welded on to the bottom of the trailer as if to take the stress off the crack.
If I were to fix it, I wouldn't do much more than has been done. I may run a bead down the outside of the crack just for practice.
I put the zerks in tonight. I wonder if I'd have been better to use a 11/32" bit. I'm not very experienced with tapping threads, and the hole being slightly smaller than it should be really made for a tough go of it. All is well, though. I pushed some grease through the bolts via the zerks to push out all the metal drillings before assembly.
I'm going to put the trailer together tomorrow when I have some daylight.
Done.
   / PM for a 500 Mile Round Trip #104
Yeah, 11/32 prob would have been OK. Since NPT taps have such a taper
to them (unlike NC, NF taps), the hole size is not critical and the deeper
you tap, the harder it gets.
Once I used press-in zerks. I never will again....only tapped zerks for me!
1999 VaXcavator VT500D T/A Towable Vacuum Trailer (A55851)
1999 VaXcavator...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
