found a railroad rail
   / found a railroad rail #33
   / found a railroad rail #35
Always wondered, does anyone know is the rolling surface hardened or not? or is it just the mass of steel that makes hardening unnecessary.
the band saw would be the cleanest and easiest of all, but not practical for out in a field.
a couple of pics of mine I got from a neighbor, is the heavy version for sure, never read the side.
JB.
Just curious how the R/R track got up in the trees? Little overkill for a dear cleaning station :confused::D
   / found a railroad rail #37
Egon,
That doesn't look like very big rail. Normally you can tell by how many bolt holes are drilled in the rail for the connecting bars. "Angle Bars". That looks to have four bolt bars making not much bigger that 112 lb rail. The roadbed looks like it is pretty well maintained for light rail, possible a business served by the RR.
That rail saw and drill is pretty impressive! I've never seen anything like in the field. In my youth i used to watch the old track guys cold cut the smaller rail. They would whack the ball of the rail with a wooden handle cold chisel then drop the rail over a tie and the rail would cut clean. Those guys never use a torch for rail that will remain in service. Goofs up the temper. In demo they use propane/Oxy.
What number is that?:D
   / found a railroad rail #38
I really do not know what weight rail its. The picture was just for pictures sake.:D
   / found a railroad rail #39
Best guess is they used it to hoist a camper off a pickup, just wonder how they got it up there! Was a little tricky getting it down, cut one tree and it got all twisted but wouldn't come out of the other.
Egon,
That's interesting, I thought it was more of a cold rolled, that sounds like how cast would act.
JB.
   / found a railroad rail #40
JB
I suppose because it' so hard. You'd be surprised how easily that rail can break. Even the big stuff especially when it get's cold. That's when our signal system comes in pretty handy. Broken rail..... red signal.
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
POWER UNIT (A51243)
POWER UNIT (A51243)
2014 CATERPILLAR 303.5E CR EXCAVATOR (A51242)
2014 CATERPILLAR...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
