Does anybody have remotes on their BX?
   / Does anybody have remotes on their BX? #1
jnjpream
Gold Member
Berthoud CO
BX22
I'm looking into putting remotes on my BX22 for top, tilt, and pivot. But I can't figure out a good place to put the valves.. Does anybody have pictures of the valve placement on their BX?
Thanks.
Jeff
   / Does anybody have remotes on their BX? #3
Iused the outlet on my backhoe to power my chute control on my snow blower.It is an open centered system,and will save you alot of money installing a remote.
ALAN
   / Does anybody have remotes on their BX? #4
I just had the valves installed on my bx2350. The plate to which the couplings are attached mounts on the right side of the ROPS and the levers for the come up through the available slot in the right rear fender. I can take a photo and send it to you but I don't know how to attach a photo here.
I have the BX7326 Valve kit which allows me to operate the chute deflector and the chute rotation.
magnatic,
I would realy like to see the picture.. Sticking up through the extra slot sounds better than being exposed on the ROPs. Is there a way to send an email to a member on TBN? I'm not sure I want to post my address in the forum..
Jeff
   / Does anybody have remotes on their BX? #6
magnatic,
Jeff
Just left click on the person that you want to send a "private message". You will see that option.
   / Does anybody have remotes on their BX? #7
I would like to se a picture too if possible
You can you put it on photo bucket and link it to forum.
or put it in pictures in the home page pull down tab and no one will get your email address
pm me if you need help and are worried about address showing up.
tom
   / Does anybody have remotes on their BX? #8
Here is my set-up.
   / Does anybody have remotes on their BX? #9
... I used the outlets for the backhoe to plumb the hydraulics for my valve. It is mounted on the ROPS...
Renob, that sounds great. It would seem that you accomplished this on a BX24. Would it be possible for you to post details on which ports on the tractor were connected to which ports on the remote valve?
   / Does anybody have remotes on their BX? #10
I used the outlet on my backhoe to power my chute control on my snow blower...
Alan that sounds great also. It would seem that you accomplished this on a BX23, where the hydraulic plumbing for the BH is a bit different from that of the BX24. Would it be possible for you to post details on which ports on the tractor were connected to which ports on the remote valve?
LINDE H80D FORKLIFT (A50854)
LINDE H80D...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
Target Ecoline Walk behind concrete saw (A49461)
Target Ecoline...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2011 TROXELL...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
