dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,619
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
That's one thing I wish there were more of out here. Basements are not common here in Calif. My understanding is that, for one, the foundation does not have to be deep in order to get below the frost line. So there is no structural need for a basement. Two, we typically to not have the boilers etc that would be seen in other parts of the country. So unless it is a custom build, you probably will not see basements out here(even the houses I know of in Truckee and Tahoe, where they get lots of snow and very cold).
I wish our house had a basement; it would be nice when it is 105 degrees in the summer... In addition to a nice expansion of the house.
If we were to move, and build a house, I would definitely want to have a basement built.
My parents house, which they inherited from my Grandfather, has a partial basement(just outside of Sacramento). But, it was an operational part of the chicken ranch; they stored eggs and stuff down there.
Do any other south-western folks know specifics why basements are not prevalent out here?
ROBERT, you are correct that builders in colder parts needed to make
foundations below the frost line. Often these houses had crawl spaces,
rather than basements, as tract builders cut costs everywhere they could.
I remember a new tract house my dad had built for us in OH back in 65 and it
was only a $500 option to have a full basement rather than a crawl space.
Most of our neighbors in nearly identical houses saved their $500 and had
only a partial basement with crawl space.
Anyway, you will find that many, if not most houses in CA built before WW2
have basements. Some were only partial cellars, used sometimes for the
furnace. Old furnaces may have used coal and depended on heat rising to
warm the house. No forced air.
One of the reasons that basements declined after WW2 is the rise of tract
building. Builders wanted to stamp out identical houses as fast and cheaply
as possible...the slab-on-grade was born. If you go look at recently built
CUSTOM houses in CA, you will find many have basements again. Many of the
newer houses in Tahoe are built by tract builders and they want to do it
the way they are familiar with, using the same sub-contractors.
As a fan of all-concrete insulated construction, I have found basements to
be very economical of energy and lot space, as well as $. Traditionally,
basements are built of cast concrete or CMUs (blocks). They are cold and
often damp. Modern insulated basements, built properly, are warm and dry,
and provide vastly superior earthquake resistance.
