Where can I hang my ramps?
   / Where can I hang my ramps? #1
8NLUGNUT
Central Texas
Several Fords, four Japanese tractors
I have been working on a "new to me" trailer for the last month and I'm just about finished up after getting some angle iron welding on the back to keep the ramps from sliding off.
I'm down to trying to find an easy access place to mount the ramps.
I'd rather not bend all the way down and have to drag the ramps out of racks welded under the deck and I don't want to have to throw them into the back of the truck.
If you guys have come u with a good way to attach ramps to your trailers please post a picture or two.
Thanks in advance!
   / Where can I hang my ramps? #2
Hinge them so they fold up perpendicular to the trailer deck and then chain them so they stay in place while in transport.
Sincerely, Dirt
   / Where can I hang my ramps? #3
Thanks in advance!
Maybe something like this.
   / Where can I hang my ramps? #4
Thanks in advance!
No ramps is one thing I like about my 8 foot tilt bed trailer.
   / Where can I hang my ramps? #6
If you aren't loading too much weight-this might work. If you have something heavy to load, then legs could be added to the ramps to carry the load.
   / Where can I hang my ramps? #7
I have legs on the back of my ramps, but I don't think you can see them. I have had over 6000 lbs on the ramps so far.
   / Where can I hang my ramps? #8
Can you make a holder on the sides of the trailer so they are mounted vertically, one per side? A quick pin can be used to hold them in place.
jb
J_J. I will be hauling our Hinomoto E232 with a FEL and a shredder on the back
and it's a 16ft trailer so I don't think I can have the fold up ramps
I do like the leg on the ramps you have but that would be too heavy for me and my bad back unless I attached them permanantly.
It will have to be a bracket or rack of some kind.
I thought about laying across the tongue but that puts me carring them back to the rear each cycle.
   / Where can I hang my ramps? #10
after looking at the pictures, i'm thinking a new set of ramps are in order for methis spring....
Enmark Z Spray (A53316)
Enmark Z Spray...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2021 CASE IH Steiger 540 AFS Connect QuadTrac Tractor (A53485)
2021 CASE IH...
DETROIT DIESEL ONE BOX (A55745)
DETROIT DIESEL ONE...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
