Tractor for moving and stacking big round hay bales
   / Tractor for moving and stacking big round hay bales #11
Using a JD 4120 with forks, I dont have a dedicated spear, I can remove one fork and use the other as a spear to stack 2 high.
Just make sure you always use it as a spear and not as forks, or you'll soon end up with 1200 lbs in your lap.
-Jer.
   / Tractor for moving and stacking big round hay bales #12
I have seen a guy using a skid loader (1700# cap) spearing hundreds of round bales, laying them on their sides, then pallet forking them on their sides into place using 48" forks, he placed 2 of them on top of each other then placed those 2 on top of a third, so they were stacked 3 high on their sides. Thses were 4'x5' Claas net wrapped bales.
   / Tractor for moving and stacking big round hay bales #13
round these parts there are quite of a few people that stack them this (for some reason i cant get the spaces right in that... prymid style)
. o
. o_o
. o_o_o
. o_o_o_o
under a qunza hut (half round building) so its often to see them stacked 3 or 4 high.
   / Tractor for moving and stacking big round hay bales #14
He likely also has a fully enclosed cab that'll prevent him from being squished like a bug if that bale comes back on him.
-Jer.
   / Tractor for moving and stacking big round hay bales #15
You are correct- he has the enclosed cab. The way he stacked them fully utilized the straight wall and was able get 400+ bales in a 60'x100' barn, with room for some equipment, etc. He is a VERY experienced construction equipment operator.
   / Tractor for moving and stacking big round hay bales #16
Wow, that's good use of space!!!
-Jer.
   / Tractor for moving and stacking big round hay bales #17
I use pallet forks for handling round bales. It sure is nice when I use a tractor with a spear.
If you have soft core bales it might work better but even with one fork removed spearing a bale is sometimes a pain in the rear. After the bales have sat 6 months it works a lot better.
   / Tractor for moving and stacking big round hay bales #18
we used to stack em 2 high with an AC 5040, probably don't weigh 6k with the loader and ballast. Not sure i'd go more than that with our setup- but you've got a ton or more on the ground than we did. As long as the loader will put em up high enough I'd say go for it.
   / Tractor for moving and stacking big round hay bales #19
I am a little old school and I realize it is not recomended by the tractor dealers but I stack my round bales 2 high with a JD 790 with a bale spear. I also unload 2 high off of my trailer which is a little stretch because of height. I used to use pallet forks and I would have to stand them on end (flat side down) to keep from breaking all of the strings, but it still worked. Spear is much faster and I like the small tractor in the barn.
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2021 MacDon FD135 Flex Draper - 35' (A59814)
2021 MacDon FD135...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
