Fromjim
I just bought a new M 108X Kubota tractor, this is a very nice tractor but I noticed something unusual, the rear wheels have cast centers and as I examined them I noticed that the wheel nuts in the center of the hub seem to be installed backwards, the nut has a thick washer next to the cast hub and the flat part of the nut is against the washer with the sloped side of the nut facing out, the opposite of what you would expect, also I see that the studs do not extend past the nut, that is the stud is about 2 or 3 threads from the end of the nut, usually there are a few threads outside the nut.
Does anyone have access to the specs. for these nuts/studs, I noticed the part number of the studs in my parts book is different depending on the type of wheels you have, steel vs cast centers.
I live a long way from my dealer and don't want bother him if this is OK, but I have had tractors for over 20 years and have never seen this before.
I would appreciate your input before I contact my dealer.
Thanks
Jim
Thanks
Jim
