Cat_Driver
- Joined
- Jan 15, 2008
- Messages
- 2,359
- Location
- Coachella Ca.
- Tractor
- 2016 Kubota 4060, 2017 Tackeuchi excavator TB260
These are the top ones
I've use all of then on various diesels and I'm down to the FPPF and redline at the moment.
I won't keep using a product if I can't FEEL the difference, and with the two I use I can definitely tell they are working. More power if I'm using the power booster formula, or a much quieter smoother engine if I'm using lubricity formula.
Best way is to try them out and find which one you like for your application.
Power Service Diesel Fuel Additives :: Diesel Fuel Suppliment & Diesel 911
Stanadyne Diesel Fuel Additives Including Performance Formula, Lubricity, Winter 1000 and Gas Injector Cleaner
Lucas Diesel and Gasoline Additives for Oil, Transmission, Injectors and Power Steering
Racor Diesel Fuel Additives :: Diesel Biocide & Coolant Treatment
Red Line Oil: Fuel Additives
FPPF
http://www.fppf.com/dieselpowerteam.asp
FPPF
