can anyone tell me how to fix a kubota tire?
   / can anyone tell me how to fix a kubota tire? #1
deereboy72
Hillsboro OR
I used a kubota today and switched off with another operator we loaded some tree branches into the fork bucket and he drove to put it in the burn pile a tree limb on the ground knocked off the tire valve and the tire started leaking the fluid i don't have the valve as i lost it but will get another one can someone tell me is there any other fluid to put in it so i can use the tractor tomorrow?
THANKS AHEAD OF TIME :)
   / can anyone tell me how to fix a kubota tire? #2
You're replacing the valve stem? If you need to use it tomorrow, don't see why you can't use it with a new stem and airing the tire without replacing any tire liquid for now.
Don
   / can anyone tell me how to fix a kubota tire? #3
Some use window wash
   / can anyone tell me how to fix a kubota tire? #4
A 50/50 anti freeze mix will do the trick.
   / can anyone tell me how to fix a kubota tire? #5
If you ripped the valve stem off, you are down until you get a tire stem. You will have to break down the tractor tire and replace the stem. I have a tool that will replace a tire stem from the outside. What it does is to compress the stem bottom enough to insert it in the rim, but I am here and you are there.
   / can anyone tell me how to fix a kubota tire? #6
In Oregon I think you could just use water. I can almost go thru the winter in Virginia without draining mine. The convenience otherwise is great.
larry
   / can anyone tell me how to fix a kubota tire? #7
Pull the visa out and call the tire guy. :D
   / can anyone tell me how to fix a kubota tire? #8
When I busted off the valvestem I parked it with the valve up so it would not leak. Took the wheel off and took it to the tire shop. $25 got it fixed and topped up for the little fluid that leaked.
   / can anyone tell me how to fix a kubota tire? #9
If this is a rear tire of any size, do as Will said. It is worth the price not to deal with a large loaded tire. They can weight hundres of pounds. They will fize it on the tractor and fill if you have a water source (well they do here).
   / can anyone tell me how to fix a kubota tire? #10
THIS IS THE WAY TO DO IT. What a time and money saver, and anybody can do it.
Here is a valve stem insertion tool from the outside of the tire. No breaking down the tire. Sears has it.
Stride Tool Imperial Tire Valve Tool - TV-90 at Sears.com
Re: Tire valve tool?
This is What the MAC TOOLS flier says about it...
a - Insert T handle between rim and valve stem
b - Turn T handle 1/4 turn to hook valve stem and pull out
c - Thread new valve stem on end of plunger rod
d - With insertion cone positioned over stem hole, push the plunger rod/valve stem completely through the insertion cone
e - pull back to seat the valve stem
2007 Ford F-150 Crew Cab Pickup Truck (A55788)
2007 Ford F-150...
2011 Ford Ranger Ext. Cab Pickup Truck (A55852)
2011 Ford Ranger...
2015 Ford F-150 Ext. Cab Pickup Truck (A55788)
2015 Ford F-150...
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
2015 Kia Sorento AWD SUV (A55758)
2015 Kia Sorento...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
