can anyone tell me how to fix a kubota tire?
   / can anyone tell me how to fix a kubota tire? #1
deereboy72
Hillsboro OR
I used a kubota today and switched off with another operator we loaded some tree branches into the fork bucket and he drove to put it in the burn pile a tree limb on the ground knocked off the tire valve and the tire started leaking the fluid i don't have the valve as i lost it but will get another one can someone tell me is there any other fluid to put in it so i can use the tractor tomorrow?
THANKS AHEAD OF TIME :)
   / can anyone tell me how to fix a kubota tire? #2
You're replacing the valve stem? If you need to use it tomorrow, don't see why you can't use it with a new stem and airing the tire without replacing any tire liquid for now.
Don
   / can anyone tell me how to fix a kubota tire? #3
Some use window wash
   / can anyone tell me how to fix a kubota tire? #4
A 50/50 anti freeze mix will do the trick.
   / can anyone tell me how to fix a kubota tire? #5
If you ripped the valve stem off, you are down until you get a tire stem. You will have to break down the tractor tire and replace the stem. I have a tool that will replace a tire stem from the outside. What it does is to compress the stem bottom enough to insert it in the rim, but I am here and you are there.
   / can anyone tell me how to fix a kubota tire? #6
In Oregon I think you could just use water. I can almost go thru the winter in Virginia without draining mine. The convenience otherwise is great.
larry
   / can anyone tell me how to fix a kubota tire? #7
Pull the visa out and call the tire guy. :D
   / can anyone tell me how to fix a kubota tire? #8
When I busted off the valvestem I parked it with the valve up so it would not leak. Took the wheel off and took it to the tire shop. $25 got it fixed and topped up for the little fluid that leaked.
   / can anyone tell me how to fix a kubota tire? #9
If this is a rear tire of any size, do as Will said. It is worth the price not to deal with a large loaded tire. They can weight hundres of pounds. They will fize it on the tractor and fill if you have a water source (well they do here).
   / can anyone tell me how to fix a kubota tire? #10
THIS IS THE WAY TO DO IT. What a time and money saver, and anybody can do it.
Here is a valve stem insertion tool from the outside of the tire. No breaking down the tire. Sears has it.
Stride Tool Imperial Tire Valve Tool - TV-90 at Sears.com
Re: Tire valve tool?
This is What the MAC TOOLS flier says about it...
a - Insert T handle between rim and valve stem
b - Turn T handle 1/4 turn to hook valve stem and pull out
c - Thread new valve stem on end of plunger rod
d - With insertion cone positioned over stem hole, push the plunger rod/valve stem completely through the insertion cone
e - pull back to seat the valve stem
Sweepster 60" Bucket Broom Attachment (A50775)
Sweepster 60"...
2021 Ram ProMaster City Van (A55788)
2021 Ram ProMaster...
Pallet of Fluorescent Traffic Cones (A55787)
Pallet of...
2020 Case TV450B Skidloader (RIDE AND DRIVE) (A50775)
2020 Case TV450B...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A55787)
2025 SDLL30 Mini...
202473 (A54757)
202473 (A54757)
