Steel Wool Filter for Kama 554
   / Steel Wool Filter for Kama 554 #21
I still do not see why you guys with the expensive filters don't get a K&N type filter that is washable and re-oiled. Just another reason for a modification.
By the way my Jinma uses a filter I get at Advanced Auto for under $4 made by Puroilator. Guess I am lucky there. Bought all 6 they had last summer because I felt they may have been priced wrong.
Chris
   / Steel Wool Filter for Kama 554 #22
Well, I have one on my Mercedes. But it's vehicle-specific, as are virtually all K&N systems. That said, it's clear that cost is the reason you don't have one on your Jinma. Cuz for the price of some K&N systems ( www.FixThisRide.com - "77 Series Performance Intake System: 1997-2003 Ford F150 pickup Polished" ) I could buy over a dozen OE cartridges.
I like my pre-filter idea better. Matter of fact, K&N has their own line. I just haven't found one yet that will fit over the big KAMA cartridge.
//greg//
   / Steel Wool Filter for Kama 554 #23
You couldn't give me a K&N filter. They let way too much dirt through. One cost me a $500 turbo (part only) because it let dirt through and dinged the blades. Many studies support the dirt fact.
In fact if anyone has a 96-97 Ford Powerstroke I'll give them my K&N for the cost of shipping, its been stored for years now, wish I'd never tried it.:cool:
   / Steel Wool Filter for Kama 554 #24
My oil-bath filter has a cyclone on the intake that throws dirt into a cup. I understand the paper filters with the plastic fins are supposed to create a cyclone effect. Where does that dirt go? (I don't have one obviously) Anyhow one option for a pre-filter is a cyclone to catch all of the larger/heavier particles either in a can or (more effectively) scavenged using something like a fan or an exhaust venturi.
   / Steel Wool Filter for Kama 554 #25
Your oil bath almost certainly has to be a vertical installation. The housings we have (mine anyway) are mounted horizontally, the cylindrical filter element installed horizontally as well. The fins you describe - with the help of gravity - cause solid particles to drop to the bottom of the housing, and move eventually toward a rubber flapper "drain" port. My TS354C filter has these fins, and aftermarket equivalent is available at NAPA. But the KM454/504/554 uses a much larger cartridge with no fins - and no American aftermarket equivalent (that anybody's yet found).
//greg//
   / Steel Wool Filter for Kama 554 #26
I bought a Chinese copy of a K&N for a F-150 for $25 on Ebay. Been on my truck and now my brother-n-law's truck for 8 years now. Just wash it out every 10,000 miles and re-oil. The have Generic non specific filters at Auto Zone with a 3" inlet. You simply adapt it to the intake tube and attach with a large hose clamp.
Chris
   / Steel Wool Filter for Kama 554 #27
This might be before your time. But I had an uncle that bought into that scam about using a roll of toilet paper as "the last oil filter you'll ever buy". He and his beautiful 1956 Oldsmobile Super 88 coupe - died not long after each other.
//greg//
   / Steel Wool Filter for Kama 554 #28
Been running the washable filters on all 3 of my trucks without a single issue plus numerous others that I have owned. Well over a 300,000 miles and never a problem. Now I did have a engine blow up at 30,000 miles due to a bad oil pump.
Either way, just a suggestion.
Chris
   / Steel Wool Filter for Kama 554 #29
Chris
If you wash your filter every 10k miles, why don't you just use a paper filter? Where I live the stuff to wash and re-oil the filter costs as much or more than the paper filter. :eek:
   / Steel Wool Filter for Kama 554 #30
Depends on the vehicle. My trucks run about $45 each for the paper filters. Granted they last a long time. My tractor and my Saturn filters cost under $5 each so paper is the way to go.
Chris
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
New Calf Hut (A50515)
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
CRESCENT SUPPLY 20 CONTAINMENT TRAILER (A50854)
CRESCENT SUPPLY 20...
2014 International Durastar 4300 (A50323)
2014 International...
