Burning ULSD in Kerosene Heater?
/ Burning ULSD in Kerosene Heater? #1
mrutkaus
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
So I've tried ULSD in kerosene lamps, works fine, just wondering, since it is cheaper, how it will do in a kerosene heater.
When I buy kerosene there is a warning label on it saying it is high in sulfur.
I'm thinking that ULSD might be even "purer" than the kerosene and burn cleaner but I want to ask experts if there's anything I'm missing.
Mike
/ Burning ULSD in Kerosene Heater? #2
I always use ULSD in my kerosene heater. I was working in my garage which is in my basement. I ran out of diesel and ran to a local mart. They don't sell diesel but do have kerosene. After 10 minutes my wife asked what I was doing downstairs, she said I was stinking up the house. Never noticed it or had any complaints while using diesel. This is a fan forces space heater and is about 10 years old. Works great and is always ran with diesel.
that's what i was hoping to hear, i'm going to try it tonight, first in a mixture!
thanks
mike
50-50 mixture in standard wick type kerosene heater working perfect no smell for several hours...(there was no smell with all kerosene either).
mike
/ Burning ULSD in Kerosene Heater? #5
I'd like to know how this works out for folks also. Especially now that I've got a 15 gallon drum with a 12 pump/14' hose and nozzle that I use to fill a Kubota B3030.
I guess that I'd just as soon have one fuel both tractor and Kerosun that I use every now and then in the garage.
NOPE!
Don't do it, even a 50-50 mixture of ULSD and kerosene caused a circular wick type heater to decrease output during the night and when I looked at the cooled down wick, it was encrusted with hard stuff which kerosene doesn't do or else takes way longer to do.
Mike
/ Burning ULSD in Kerosene Heater? #8
Kero is still a lighter fraction than #2 fuel oil. ULSD is still #2 while Kero can be called #1 fuel oil and is added to #2 in colder climates to slow/stop 'gelling'...
I used to work for the US office of a Canadian Motor Carrier and had a guy load in Panama City, FL and he fueled up there. 24 hours later near Thunder Bay, ON his tanks gelled solid, had to have him towed to a heated shop and after 24 hours & a few gal of HOWES conditioner they got him re-started enough to top him off w/ winterized fuel.
There is more wax, etc. in #2 than #1 and removing the sulfur does not change that.
/ Burning ULSD in Kerosene Heater? #9
You don't want to run kerosene in your tractor.
/ Burning ULSD in Kerosene Heater? #10
When kero heaters first came out it was hard to find fuel in out area so I used to go to the airport and pick up jet fuel. It worked great.
/ Burning ULSD in Kerosene Heater? #11
The intent was to use ULSD in the Kerosun. But the post about the wax content being more in ULSD than in kero, regardless of sulfur content leads me to believe that I'll continue using separate fuels for each.
/ Burning ULSD in Kerosene Heater? #12
The best thing to do is use the right fuel in the right equipment.
Kerosene in the Kerosene heater.
Diesel or HHO in the tractor.
As for the 50/50 mixture of the 2 fuels I might chance screwing up a 200 space heater with it.
No way would I take a chance on destroying a $20.000 tractor with that mixture.
/ Burning ULSD in Kerosene Heater? #13
I was chatting with the guy at the fuel distributor a couple of years ago when Kerosene shipments were on an alotment basis. He confirmed that K-1 (kerosene) and Jet A were almost the same -- Jet A has some additional additives put in it (like water dispersant, anti-corrosion, ... that you would want in Jet fuel but wouldn't need in kerosene for heaters and lamps).
/ Burning ULSD in Kerosene Heater? #14
I heard that old timers mixed kerosene with diesel or run straight kerosene in tractors in really cold climates before the howes, power service was around. I probably would do it in the winter when its 0 or below, but not in the summer since kerosene burns hotter then diesel.
/ Burning ULSD in Kerosene Heater? #15
When I was kid we used to have a cottage by the lake without electric power. Therefore we used wick kerosene lamps (I think we called them storm lamps). When filled with diesel the flame was kind of reddish and didn't provide nice light. It also took for a while before the glass cleared. When filled with kerosene the lamp burned bright yellow giving much better light and it took only short time for the glass to clear up.
/ Burning ULSD in Kerosene Heater? #16
1*I heard that old timers mixed kerosene with diesel or run straight kerosene in tractors in really cold climates before the howes, power service was around.
2*I probably would do it in the winter when its 0 or below,
3*but not in the summer since kerosene burns hotter than diesel.
1*Old timere aren't always rite.
2*Not me because you'd be getting to much Kero in the Diesel due to the mixing.
3*Winter or summer /hotter burning makes no difference.
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
2014 Freightliner 105' Bucket Truck (A61306)
2014 Freightliner...
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61306)
2023 Kubota...
2003 Freightiner FLD120 (A61306)
2003 Freightiner...
