Rob, it's been a while since I looked at your projects, you certainly have been busy.
Tell me about your solar are you finding that you generator almost never is needed?
I am getting ready to start my home in S.E. San Diego county and will be off grid as well.
I forgot what you elevation is there but my citrus never made it at 3,300 feet, they are alive after three years but have not grown more than an inch or two. All of the decidous fruit trees like the cold and hot and are doing well. Not sure about avocados where you are but no way would they make it at my place unless I smudged.
Derik
Derik,
Our elevation is only 1500 feet at the homesite where the orchard and garden will be.
The rest of the property is a good 100 to 200 feet below that. Last week we had another cold spell but temps got back into the 70's just before we left. Next week it's supposed to get into the 90'sF.
I'm happy to report we have made many adjustments to cope with off grid living.
Everything runs off our solar ... everything. Our back up generator helps out when there is no Sun, but other than that, it's all off the solar. the generator runs more in the Winter due to shortened days and less sunshine due to rainy days or bad weather.
Our adjustments were to make sure we unplug (via electric strips) all unnecessary equipment.
We turn the computers off except when using them. Same with the TV and radio etc. We even unplug our electric shavers and tooth brushes lol. We also changed every single light to either CFL and many to LED. The saving in energy consumption was astronomical. Typically, we've cut down from about 28 to 30 kW use daily down to between 8 and 13 kW a day. Maybe 18kW when using the electric drier. We expect our use to go up a bit if we use the air conditioning system. But we also have more sunshine then.
It depends how much washing and drying we do.
The rest is pretty typical for us to use about 10kW-16kW a day on average. The adjustments were inconvenience at first, but after 9 months now, it's no big deal. Our biggest power users are the electric drier so we run that when the generator kicks on. I need to run the generator when I run my big lathe which is rarely. The Direct TV uses a lot of energy too, so it's unplugged all the time except when we watch TV. We even have 8 sets of accent light around the home and barn. They are dusk to dawn lights with 2 bulbs in each fixture. We put 1.5w LED's in them so all together they draw 24w total for about 10 hours, or .24kW for the night.
The solar is holding up nicely with very little trouble once we got it tuned in and the batteries balanced out.
That took many charges with the generator to get them into float, but it's all working great right now. The big thing is monitoring the system and watching (make a habit) to use as little electricity as possible.
Peter has helped us a lot with tips along the way and what he's done with his system.
Rob-
