I went w/Bars when I purchased the
BX23 and ran it that way for 3 yrs.
Later I found a set of low hr turfs and purchased them for a pretty good price. This is my 2nd season on them.
On my property, which varies from a nice finished lawn for approx 1.5 acres to former pasture covering approx 2.75 acres, I MUCH prefer the turfs for finish mowing.
They do less marking of the lawn in corners and they give a softer ride.
When I 1st purchased the
BX23 I was doing nearly as much TLB work as I was mowing so the Bars proved to be benefitial, especially since I was operating in mud and soft dirt.
Now adays the
BX23 does more finish mowing than TLB work and the Bars would leave noticable markings in even lightly damp turf, especially when mowing around trees and in turns, the turfs don't.......
My conclusion,
If primarily finish mowing, go with turfs. btw, thats why they were designed........
In mud the turfs are atleast twice as likely to get you stuck and they'll spin in loose soil. The Bars are great in these types of environments as those big turf marking cleats can take hold much easier. I don't get much snow and when working in the little I do get both seem to perform the same (i.e. a wash).
TLB work especially in soft soil and mud = Bars. btw, thats why they were designed....
R4's seems to be a great compromise. Their cleats aren't as aggressive as the Bars and they have more flat area which distributes the wieght of the tractor over a larger turf area. They should be less likely to mark and give alittle better traction in mud and loose soil.
R4's weren't an option for the
BX23's (Bx-XX30's series) because of the odd wheel size but with the introduction of the BX-XX50 and 60 series and the the change to the more common larger wheel diameter size, R4's are now an option for our older BX's. The 50 & 60 series front wheels will fit on the older 00 & 30 series..
If I were buying today my choices would be between the R4 and Turf and I'd probably go with the R4.
YUMV.
