Oil & Fuel JD 3320 Position of Implements when Checking / Changing Oil
   / JD 3320 Position of Implements when Checking / Changing Oil #1
jbk
I own a JD 3320. When checking the oil I've been told that the loader, backhoe, etc. should be in a position where the hydro pistons aren't exposed, and oil is, essentially, only in the tractor. I would think it should be the opposite - that oil should be checking when the hydraulics are full and the pistons fully exposed. Any assistance here appreciated.
Thanks Much,
John
   / JD 3320 Position of Implements when Checking / Changing Oil #2
I would think that it shouldn't make a difference because they are all double acting cylinders (same amount of fluid in cylinder at all times).
Thanks FP. I think the oil position on the dipstick varies with the position - which adds a bit of confusion. I'll be checking it today and will report back later.
   / JD 3320 Position of Implements when Checking / Changing Oil #4
Great answer! All the implements should be in a lowered position when checking hydro oil. The level is not super critical, it will always vary a little depending on if the loader and/or backhoe is attached.
   / JD 3320 Position of Implements when Checking / Changing Oil #5
Except for the volume occupied by the cylinder rod.
   / JD 3320 Position of Implements when Checking / Changing Oil #6
Good point RickB....I didn't think about that.
Thanks for all the responses. I agree. The volume occupied by the cylinder rod is what makes that difference. I was testing this yesterday and that is surely the case. That said, even when the implements are down the oil level drops to the lower end of the range in the dipstick (assuming it was at the high level before).
Thanks again,
John
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2005 John Deere 7420 (A60462)
2005 John Deere...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
