Made Some Side Rails For My Trailer
   / Made Some Side Rails For My Trailer #1
hunterridgefarm
Western NC
Kubota L3130DT, Kubota L185DT, JD LX277
I finally got around to making the side rails for my trailer. I used treated wood and bolted it together.
I made corner brackets out of metal at work to hold the front on. I made it with a two piece rear gate. I did not go the full length of the trailer so I could open the rear gate without droping the ramps.
   / Made Some Side Rails For My Trailer #2
Looks good.
I've often thought about doing something like that with mine.
Are your corners quick connect or screws/bolts ?
   / Made Some Side Rails For My Trailer #3
Nice looking trailer and truck. I really like the brackets you made.
Chris
Looks good.
Brackets are screwed in. I ran out of bolts. I was looking for some heavy hinges with removeable pins but could not find any and did not want to drill the pins out. I can remove the screws on one side of the brackets and lift the sides off.
   / Made Some Side Rails For My Trailer #5
Nice job on the rails and brackets.
I made a set on mine so i can haul 125 bales of hay and don't have
to strap it down, then i take mine off.
But i really like the way you fixed the brackets.
Thanks for sharing
_________________
Bill
   / Made Some Side Rails For My Trailer #6
I picked up some corner brackets from Northern Tools. They had the straights too. They had them in stock back in the trailer section. They work great if you're making the sides removeable.
Thanks for sharing
_________________
Bill
Bill,
Thats one of the reasons I made these. I need to haul some straw to seed the yard. I was unable to get any grass started last year due to the drought.
I also have a lot of things I need to haul that would be hard to strap down but will travel great with the side rails.
David
   / Made Some Side Rails For My Trailer #9
That's what I am starting right now. I got mine at Tractor Supply:
Tractor Supply Company - Carry-On Trailer Left & Right Corner Brackets
My local store had the straights too. I'm just collecting the lumber and brackets now so it will be a few weeks until I'm done (I plan on having it ready for the spring mulch season!)
   / Made Some Side Rails For My Trailer #10
David,
Nice work on build those sides for your trailer.
Dang, you reminded me of another project to do. I've been wanting to do that for a year now. Yours really came out nice.
What are you pulling with?
Thanks,
Rob-
David,
Thanks,
Rob-
2002 F250 Powerstroke, 50,000 miles.
I could of made the rails a little nicer but was pressed for time. I have some granite I need to haul from the other farm. They are a good size for a stacked wall I plan to do infront of the house. I should be able to haul one or two layers with the siderails on. Plus I have some creosote beams and old odd and end things from the old farm house we plan to use.
PS: Don't show me up too bad when you make your side rails...maybe wait and post once my thread gets about 15 pages back!!:D:D
David
   / Made Some Side Rails For My Trailer #12
David,
Your sideboards look great to me. I intend to do the same thing IF I can ever find a trailer I like....
Good job.
   / Made Some Side Rails For My Trailer #13
Dave, could you post a few pics of the truck? I looks like we may have twins.
Nice job on the rails!!
Matt:D
Matt:D
Matt,
This is the only pic I have of the truck on file.:)
   / Made Some Side Rails For My Trailer #15
I would like to do the same, I am wondering if I can put process, or gravel, or top soil in it, and unload it with my loader? Any one ever try that?
   / Made Some Side Rails For My Trailer #17
New member and found your posting while Googling about side rails for a trailer. I need rails for my 20' trailer to carry "old" Marines in a parade soon. Your photos and comments are helpful.
Gary
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
159120 (A60430)
159120 (A60430)
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
John Deere 1025R (A53317)
John Deere 1025R...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
