RTV 500 Rattle Sound
   / RTV 500 Rattle Sound #121
kubota is sending out a service truck next Thursday, I will let you know what they are going to do about fixing the rattle sound.
Keep us posted on your findings...Ask him if there are any secrets to eeking some more power out of this...not speed, just power, mainly in high range...
I started this thread and because I have a Rtv 500 and it has since 0 hours an annoying metal rattle sound coming from the alternator drive. Well it's true the squeaky wheel gets the grease and that's what appears to be happening. Got a call from my Kubota dealer to bring it in that they think, and I say that again, think, they have a solution to quiet down the rattle issue. I will post what they did and the results. I failed to ask if this was a Kubota tech bulletin or a in house fix. At least they know about it and sounds like a fix is in the works......
   / RTV 500 Rattle Sound #123
When the service truck arrived, he was more interested in chaulking the timing chain cover, the timing belt is getting wet. (Kubota tried using a peace of foam). I had already lossened the alternator belt, which reduced the noise by 75%. He did not have any ideas on increasing the power of RTV 500, only on the 900's and 1100's.
   / RTV 500 Rattle Sound #124
Timswi- I have started using 92 octane gas. I think is helps a little.
   / RTV 500 Rattle Sound #125
DLH...I'll give that a shot...If I can find some Turbo Blue, I'll do that too...Thanks
   / RTV 500 Rattle Sound #126
I bought mine at the first of may and there is no rattle sound on mine. My salesman did mention the timing cover fix. They have to drill a hole in the bottom of it to let water escape if any gets in there.
I have heard of a revised driveshaft coupling on the 900/1100s that fixes their rattle. maybe related?
   / RTV 500 Rattle Sound #127
If you don't know what to listen for, you won't even notice it. Once you know it's there, you notice it all the time.
   / RTV 500 Rattle Sound #128
LOL, if i dont notice it, it's not a problem right??
I have been all ears with respect to this problem but i havent heard anythiong out of the ordinary. EXCEPT the cooling fan on the fuse box under the seat. That thing is ridiculously loud.
   / RTV 500 Rattle Sound #129
I didn't say it wasn't a problem.
In regards to the fans, I agree and I wonder if they were really needed. But the noise this thread is concerning is not the cooling fans. Does your RTV500 have a rattle sound?
   / RTV 500 Rattle Sound #130
Was your machine fixed?
Dual/Moyno Pump System (A50121)
Dual/Moyno Pump...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2024 Bobcat E35 Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Bobcat E35...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
750 Gallon Concrete Fuel Tank (A50774)
750 Gallon...
Yamaha Electric Golf Cart (A50121)
Yamaha Electric...
