B2920 vibration under load....
   / B2920 vibration under load.... #1
jambx
Gold Member
Southern CT
B2920 TLB, ZD21-60P, 1949 US Baird Beaver
Since I just turned 10 hours I am still working the B gently however, yesterday when I went to use my middle buster (potato plow) in the garden -(4WD, 2000 RPM) I experienced a very noticeable vibration under the deck. Now, prior to plowing I was using my bush hog and there were no problems but, later that very day I went to pull a 2000 lb trailer and noticed the vibration again (be it not as noticeable as when I was plowing). So it appears to happen when the tractor is used in a ground engagement role.
Has any B2X20 user experience anything like this?
   / B2920 vibration under load.... #2
You say under the deck......... mmm?, or hood? I haven't experienced anything like that in doing similar chores with mine yet. (55hrs) What range were you working in? 4wd? Let's try to figure this out.
   / B2920 vibration under load.... #3
I think he's referring to the operator platform/floorboard.
   / B2920 vibration under load.... #4
High frequency (follows engine RPM)?
Low frequency (follows driveline/forward speed)?
Hi Guys,
It is happening under the floor-board.
From what I can tell the vibration does not follow the RPMs - it stays constant under load (pulling something heavy).
I plan to go out tonight and really make a effort to see if I can pin-point where it is coming from - I not only hear it but to a certain degree feel it.
It almost sounds like the heat shield on my trucks exhaust system rattling around.
I had a BX22 with 700 hours and its my only real gauge and from my experience with the BX, this vibration / noise is not normal.
Why me.:mad:
   / B2920 vibration under load.... #6
I actually noticed some vibration only under load and only in 4WD. Not while I was pulling anything, but when I was moving a load of stone. It went away after I put the machine in N, pulled the machine out of 4WD, and stepped on the HST pedal. Once put back in gear everything was fine so I assumed it was my error.
It's ironic one of the main reasons I bought the 2920 was it's lack of engine vibration vs. others? Let us know what you find!
   / B2920 vibration under load.... #7
I have not seen this on my 2920.
   / B2920 vibration under load.... #9
Does the vibration sound sorta like a ratcheting noise? What gear were you in? My hst makes a kinda ratcheting sound when under load. Like when I first take off in a high gear or start to go up a steep hill. I would call it a slow ratchet and it is directly related to the movement of the hst pedal. I beleive that it is not right on mine, but have not come to any conclusions. :confused: I am guessing/hoping it is a relieve valve or something.
   / B2920 vibration under load.... #10
The only vibration noise I get on my B2620 is from the seat belt vibrating against the fender when I'm not wearing it :p
Troy
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Case 950 8 Row Air Planter (A56438)
Case 950 8 Row Air...
2007 Ford E350 (A55973)
2007 Ford E350...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
Kubota RTV X900 (A53317)
Kubota RTV X900...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
