B2920 vibration under load....
   / B2920 vibration under load.... #1
jambx
Gold Member
Southern CT
B2920 TLB, ZD21-60P, 1949 US Baird Beaver
Since I just turned 10 hours I am still working the B gently however, yesterday when I went to use my middle buster (potato plow) in the garden -(4WD, 2000 RPM) I experienced a very noticeable vibration under the deck. Now, prior to plowing I was using my bush hog and there were no problems but, later that very day I went to pull a 2000 lb trailer and noticed the vibration again (be it not as noticeable as when I was plowing). So it appears to happen when the tractor is used in a ground engagement role.
Has any B2X20 user experience anything like this?
   / B2920 vibration under load.... #2
You say under the deck......... mmm?, or hood? I haven't experienced anything like that in doing similar chores with mine yet. (55hrs) What range were you working in? 4wd? Let's try to figure this out.
   / B2920 vibration under load.... #3
I think he's referring to the operator platform/floorboard.
   / B2920 vibration under load.... #4
High frequency (follows engine RPM)?
Low frequency (follows driveline/forward speed)?
Hi Guys,
It is happening under the floor-board.
From what I can tell the vibration does not follow the RPMs - it stays constant under load (pulling something heavy).
I plan to go out tonight and really make a effort to see if I can pin-point where it is coming from - I not only hear it but to a certain degree feel it.
It almost sounds like the heat shield on my trucks exhaust system rattling around.
I had a BX22 with 700 hours and its my only real gauge and from my experience with the BX, this vibration / noise is not normal.
Why me.:mad:
   / B2920 vibration under load.... #6
I actually noticed some vibration only under load and only in 4WD. Not while I was pulling anything, but when I was moving a load of stone. It went away after I put the machine in N, pulled the machine out of 4WD, and stepped on the HST pedal. Once put back in gear everything was fine so I assumed it was my error.
It's ironic one of the main reasons I bought the 2920 was it's lack of engine vibration vs. others? Let us know what you find!
   / B2920 vibration under load.... #7
I have not seen this on my 2920.
   / B2920 vibration under load.... #9
Does the vibration sound sorta like a ratcheting noise? What gear were you in? My hst makes a kinda ratcheting sound when under load. Like when I first take off in a high gear or start to go up a steep hill. I would call it a slow ratchet and it is directly related to the movement of the hst pedal. I beleive that it is not right on mine, but have not come to any conclusions. :confused: I am guessing/hoping it is a relieve valve or something.
   / B2920 vibration under load.... #10
The only vibration noise I get on my B2620 is from the seat belt vibrating against the fender when I'm not wearing it :p
Troy
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
