Oil & Fuel $4000 Repl. Cost for JD Compact Tractor Fuel Pump??
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #11
If it turns out to be the AM880247 pump, I'll get it for $3396.30. That's what we sell ours for.
I, too, would find a reputable pump shop to rebuild it before I bought a new one. They usually offer some kind of parts and labor warranty themselves.
Thanks
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #12
And we wonder why some companies are having a hard time. A pump for a small 790 isn't worth anywhere near that much.
Steve
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #13
Sounds like another case of basing the price on the number sold. If they were selling more they could lower the price.....My son got a rebuilt Chevy pump installed by a deisel shop for 1/2 of the dealers "on the counter" price with a warranttee better than GM's
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #14
Steve
I agree...BUT...think of it this way, if you DONT get a pump, what you gonna do with the tractor? Sell it for scrap metal?
Selling a "busted motor" tractor of any sort means you're pretty much selling it as scrap..so the guy you sell it to will run down to the dealer and get the pump and have a working tractor for a "normal price".
I agree with everyone else though...Pump shop or start researching the engine...Sometimes its cheaper to get it elsewhere, more then just Deere uses Yanmar's...
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #17
I can't verify this but a mechanic friend told me there are only two companies making injector pumps and they cross over to many applications. He put a Ford pump on his old JD for $600 when JD wanted $2500 for the same pump. Might be worth doing some research on after market sources.
MarkV
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #18
Warning to any other homeowners wanting to enjoy a utility tractor for use in the yard. I was just quoted nearly $4K for a replacement pump for a tractor with only 120 hours on it.
JD 790 Part No AM880247 (Injector) PUMP, FUEL ASSY 3,905.75 USD
Am I loosing my mind or is this highway robbery? I can not afford this.
Tractor ran fine. Parked for the winter. Got in to do some work and refused to start. Discovered I lost fuel on the front injector (1 of 3) at the injector pump. Any suggestions of how to reasonably replace, rebuild or has anyone else lost fuel on an injector pump like this? HELP...
Disgusted John Deere owner,
netroglycerin
So what have you fond out about this problem?
Steve
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #19
MarkV
Maybe one of those companies would be Bosch ?
A quick search for "diesel injector pump manufacturers" would probably confirm/deny what your friend told you.
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #20
I'm afraid we might never hear from the OP again...
But with 3 posts..
1-8-2002 - bought the jd 790, hated the FEL
5-2-2009 - tractor won't start, replacing fuel lines to repair an air leak.
and this post.
Darn I hate with this happens!!
Rob
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
2016 Freightliner M2 106 4x4 Altec Bucket Truck (A55852)
2016 Freightliner...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
