Oil & Fuel $4000 Repl. Cost for JD Compact Tractor Fuel Pump??
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #21
Maybe one of those companies would be Bosch ?
A quick search for "diesel injector pump manufacturers" would probably confirm/deny what your friend told you.
I would think either Bosch or Roosamaster injector pumps for most Deeres'.
Steve
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #22
All Yanmar powered Deere compacts use Yanmars own pump. Yanmar builds the entire engine including the injection pump. I would say with less than 200hrs on the clock, that this paticular pump has had water, or some other type of contamination to cause the pump to fail.
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #24
I just had the fuel pump, AM876266 replaced on my Model 790 JD, cost was $73.20 plus about $240 labor. Actually it was not the fuel pump that kept the tractor from starting as we discovered, it was a fuse.
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #25
Didnt look it up, but $73.00 seems like that would be a Lift Pump, not the Injection Pump...if it is for the injection pump, A1!
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
John Deere 5100M (A53317)
John Deere 5100M...
Woven Landscape Fabric (A53117)
Woven Landscape...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
