Small leak on 422 front wheel motor
   / Small leak on 422 front wheel motor #41
KentT, I could not find your post on what wheel motor you used for more torque. Could you put that here or link me. Are you still happy with motor, or do you have a better suggestion at this time.
Thanks,
   / Small leak on 422 front wheel motor #42
Thanks,
Bob, from another site where I posted pictures:
I upgraded my old-style PT-425's White RS Series 12.5ci wheel motors to Char-Lynn S Series 22.7ci ones. This essentially doubled the torque while reducing the top speed to half of the stock motors. I custom-ordered the Char-Lynn motors, adding the optional Low-Speed Valving and High-Pressure seals, in addition to specifying the 1" tapered shaft and 1/2" NPT hose connectors.
Three additional modifications were required: (1) grinding out the PT's tub to clear the motors which are about 3'8" wider in diameter than the width of the rectangular White RS stock motors; (2) grinding the Char-Lynn's Woodruff key down slightly, making it "stepped" to match the keyway on the original wheel hubs which used a slightly smaller bar-type key, and (3) adding washers between the wheel hub and the retaining nut so that it would torque up tightly -- the Char-Lynn motors have a slightly longer shaft
It was about a 10-12 hour mod, overall, with most of the time spent grinding out the tub with a small air-driven cutoff tool Now, this PT (which didn't have the higher-torque 14.7ci White CE wheel motors that the new ones have) can readily climb 20-25 degree slopes and is limited only by traction, not wheel motor torque. However, the top speed is just slightly above 5MPH, so take that into consideration before you do something similar It may be TOO SLOW for your uses...
I don't regret the mod at all, for my uses. But a couple cautions: (1) these four wheel motors were expensive, over $400 each, and (b) these were special order items and I had to wait for them to be made and shipped.
It is NOT a simple "buy it and bolt it in" mod...
   / Small leak on 422 front wheel motor #43
KentT, thanks for the info. This does not sound too difficult. I would have to buy a grinder, but that's not bad. Need one anyway. Have you got a good contact to order from?
   / Small leak on 422 front wheel motor #45
Looking at your pictures, did you only have to cut out metal from one side of the opening? That's all I saw on the picture.
   / Small leak on 422 front wheel motor #46
Depended on the wheel -- as I understand it. An old friend actually installed them for me. Seems the openings in the tub aren't exactly aligned the same on each wheel, in relation to the mount for the wheel motor...
It was more a trial and error, and he removed more metal from the first one or two than what was really necessary...
   / Small leak on 422 front wheel motor #47
Again thanks for all of the info. I really appreciate that you took the risk of doing this.
Is the picture showing the cutout one of the first or is it one of the last? In other words could you remove less than shown on that particular unit.
   / Small leak on 422 front wheel motor #48
One of the first. You only need to remove material on the sides in the center of the hole -- so the circular Char-Lyn motor can fit in the rectangular hole for the original White motor. There's no need to remove material from the top and bottom on the sides, just the center. You may have to remove a little material at the very bottom, but not at the top of the hole. I've attached a quick sketch that illustrates what I'm talking about.
After you can get one to fit in there, and bolt up, you can then get a sense of how big the hole has to be for the remainder. Make sure that the motor doesn not contact the sides of the hole -- so it never puts a stress on the motor casing.
Bob, if you really intend to do this -- I'd suggest you consider going one size smaller than my wheel motors (there's a 17 or 18 ci model in the same S series) unless you're REALLY sure you need the torque. If you're going to be mowing smoother lawns or something a little more speed would be nice. I'm bush-hogging hillsides and moving tens of tons of mulch (finally done, yeah!), so I wanted a "tractor" and not a "lawn mower"... I'm not exaggerating when I said I was climbing the road bank up into my driveway with a full bucket of wet mulch. But it is slow in transit now, and I'm at full treadle any time I'm going long distances. The operation is just as smooth and maneuverable, just slower and more deliberate, if that communicates...
   / Small leak on 422 front wheel motor #49
Kent, I was thinking exactly the same thing. I don't have that many slopes and basically 40% more wheel torque would be enough. I wonder if you have to cut metal for the smaller motor. It would be nice not to have to do that. There may be a little weakening from it. Also perhaps I could not grind enough from some areas since there are other plates in the way.
I got the rebuilt motor back today. The total cost was $297.88. They put in a new shaft and seal. I saw the old shaft and there was a lot of rough areas at and around the seal contact area. I think they did right by doing this. The new seal would have worn out very fast. The kit alone was $175. Please let me know if I paid for something I did not need.
I put the new motor in and she runs great. It's nice to be Traking again. My lawn is getting pretty high. I will mow tomorrow.
Again thanks to everyone and especially Kent. What a great resource and community this is.
Hi Bob,
Do you know the exact model number of the wheel motors on your 422?
Thanks!
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A57024)
2002 Chevrolet...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
Year: 2018 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 61,082 (A56859)
Year: 2018 Make...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2021 Chevrolet...
