Which hydraulic fluid...
   / Which hydraulic fluid... #1
CentralNC
Charlotte, NC
New Holland TC35A
Which hydraulic fluid would you suggest for a TC35A? I am getting near the change time period and I like to plan ahead. I have read comments that the Kubota Super UDT is the best all-around hydraulic fluid even for non-hydrostatic tractors.
I assume that the Super UDT is a synthetic fluid that will perform well in cold climates? Would this be better than the Ambra fluid sold by New Holland? What about standard products sold by Shell or even the Tractor Supply brand hydraulic fluids?
Any comments or experiences would be appreciated. Thank you!!
   / Which hydraulic fluid... #2
You need hyd oil that meets or exceeds Ford 134 specs. If in doubt use NH oil.
NH's Ambra Multi G134 is the right oil.
JC,
   / Which hydraulic fluid... #3
If you want to know MORE about this go on the Oils forum: lots of talk on this topic!
Jim
Thanks for the advice. I forgot about the oils and fluids forum. I should have looked there first. I appreciate your comments!
   / Which hydraulic fluid... #5
That is an unbelievable story. I just bought the Ambra G134 fluid this morning. The cost was nothing vs. the price of the tractor!!
   / Which hydraulic fluid... #8
Yep.. if I'm pouring and it don't look right.. I'm draining next...
blind faith works great in some places.. in my tractor.. NO...
soundguy
   / Which hydraulic fluid... #9
My b2150 has said the schaeffers hyd. fluid is superior to kubota's. Loader stays in place when off, peddle is smoother for the hydrostat too.
   / Which hydraulic fluid... #10
Hello,
I have a Ford Model 1920 purchased new in 1988 or so and I want to make sure I get the correct fluid for the transmission. I have misplaced the Operators Manual and can't find one on-line. I have a Tractor Supply nearby, do that have a good oil?
How can I be sure I am getting the correct fluid? I just replaced the brake disks and don't want problems because I put the incorrect oil in it.
Thanks,
Dpaul
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2021 Dodge Ram 2500 Promaster (A50120)
2021 Dodge Ram...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
