Oil & Fuel $4000 Repl. Cost for JD Compact Tractor Fuel Pump??
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #21
Maybe one of those companies would be Bosch ?
A quick search for "diesel injector pump manufacturers" would probably confirm/deny what your friend told you.
I would think either Bosch or Roosamaster injector pumps for most Deeres'.
Steve
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #22
All Yanmar powered Deere compacts use Yanmars own pump. Yanmar builds the entire engine including the injection pump. I would say with less than 200hrs on the clock, that this paticular pump has had water, or some other type of contamination to cause the pump to fail.
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #24
I just had the fuel pump, AM876266 replaced on my Model 790 JD, cost was $73.20 plus about $240 labor. Actually it was not the fuel pump that kept the tractor from starting as we discovered, it was a fuse.
   / $4000 Repl. Cost for JD Compact Tractor Fuel Pump?? #25
Didnt look it up, but $73.00 seems like that would be a Lift Pump, not the Injection Pump...if it is for the injection pump, A1!
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2017 FORD F550 XL SERVICE TRUCK (A57192)
2017 FORD F550 XL...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2021 Ford F-250 Crew Cab Pickup Truck (A55852)
2021 Ford F-250...
