How safe is Manual Trans vs HSD
   / How safe is Manual Trans vs HSD #51
By the way the dealer had me do a little test while trying out the B2320 DT.
I forget if I was in Medium or Low.
But I was in 1st gear.
The engine was idle and he said pop the clutch (no gas needed).
So I'm rolling along at a crawl and he says hit the brake.
1*It did ABSOLUTELY nothing. It didn't even even slow it down, it was as if I didn't even touch the brake. There was not momentum here, I was crawling like a snail. It was brute power.
I know on my BX24 with HST it would stop when crawling along like that. Only at high RPM fully engaged HST it had power.
2*If I forgot to release brake on BX24 it would not move.
It was a little scary actually. If you panic and not hit that clutch you're in deep doo doo.
3*Why wouldn't you hit the clutch too?
1*It would be bad if car brakes worked like this as hitting the brakes is supposed to slow the car down even if the clutch is not hit.
2*If it moved the brakes would not be rite.
3*Why would you depress the clutch every time you hit the brakes on a stick shift car?
   / How safe is Manual Trans vs HSD #52
I didn't say I would :rolleyes:
We were talking about a panic situation.
I would have to say it has pretty crappy brakes if you can't stall the tractor at an idle.
   / How safe is Manual Trans vs HSD #53
I was thinking the same thing!:D
Brakes not stopping an idling tractor in gear doesn't show that it has power, it shows that it has lousy brakes! :eek: The salesman was pretty clever to turn the deficiency around though. Good reason not to trust salesmen!
The brakes are absolutely fine. It was so geared down it was like a train and you just can't stop it. It will stop on dime if you push in the clutch.
   / How safe is Manual Trans vs HSD #55
My choice on a gear vrs HST had nothing to do with safety reasons, although I believe the HST to be a much easier drive to operate, and that in itself may make it a little more safe. I bought my Kubota gear drive L2600DT with FEL about three months ago. I was looking also at a L3010 HST Grand Series also equipped with a FEL.
After reading numerous posts on this site about HST trans, I decided on the gear model because I just didn't want the added maintenance of the HST. I use my tractor very little, very light work, and it sits-up a lot. I also don't know alot about tractor hydrolic systems, so I felt my best bet was a gear tractor. I can block my clutch and not worry about a several thousand dollar fix if something like a HST pump quits working for whatever reason. My belief is the more something isn't used, the more things get hung-up, stuck, etc.
I know people have the same type of preference for HST, and if I was using my tractor several hours a week, particularly using the FEL, I would have more strongly considered the HST Grand.
   / How safe is Manual Trans vs HSD #56
I'm sorry but the brakes should be able to overcome the engine at an idle.
That is also one part of my reason for going with gear. I like the simplicity.
Do you think these HST's will still be running like 50-80 year old Geared Fords and Simplicity tractors. I doubt it.
I also agree if your doing a lot of FEL work HST would probably be better.
   / How safe is Manual Trans vs HSD #60
I seriously doubt very many of these new tractors, HST or gear, will be running (much less still making themselves useful) 50+ yrs from now. New tractors aren't overbuilt the way they once were.
Commercial Kitchen Equipment (A56860)
Commercial Kitchen...
2013 EZ-GO RXV Golf Cart (A57453)
2013 EZ-GO RXV...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
1969 VOLKSWAGEN BUG (A59575)
1969 VOLKSWAGEN...
