best disc harrow?
   / best disc harrow? #21
I have a King Kutter and it works fine for my needs. It would be better if the adjustments were easier, but I can live with that. One thing that you definitley need to consider is disk scrapers. The KK do not come with them. Disking dry dusty areas mid summer is not an issue. But early spring when there are wet areas, there is nothing more frustrating than plugging the disks with soil. It doesn't take much moisture to start a clod between disks and within a few yards it's packed solid. No matter how dry 95% of the field/plot/garden is, there always seems to be a few areas that plug the disk. Then it takes 5-10 minutes of intense shoveling and chipping to get hard packed clay cleared out. I'd bet since you are doing food plots you will be in some damp areas, so I would stick with a disk that has scrapers.
Good luck.
   / best disc harrow?
Good luck.
Thanks for the tip on the scrapers. I've had that issue with my ATV disc, so I can appreciate the work saved by having them.
   / best disc harrow? #23
Scrapers are largely dependent on soil types IMO. "Up North", where I have my land the soil is all sandy loam and scrapers wouldn't be worth two hoots in a tin can in any conditions. OTHOH, I live in southern MN.....and here scrapers can be of value in the spring and fall in heavy, sticky soils and wet conditions.
   / best disc harrow? #24
That is the only problem I had with that JD pull-type disc I found this spring. The scrapers on one of the sections does not work so well. Fixing it up will be be a good winter project. I am not sure why FWJ ignores the fact that I said this pull-type disc does MORE effective work on the soil than (2) 3 pt disks I have used (MF and Ford), and takes less passes to get the field worked as well. Also, the corn in the fields that I worked with the pull-type is growing as good or better than that in fields where I used only a 3 pt or transport disc, so much for the "compaction" argument. Again, that is a non-issue this far north of the mason dixon line. Up here, shallow tillage is the best way to go as it saves fuel and I only plow 4-6" deep. Maybe he had a bad experience with a pull-type when he was young, and has since lumped them all together saying they are no good for anyone for any reason wherever they may live. It appears that I struck a nerve with this issue. Usually he is on the mark with his advice, but he has missed the boat this time and appears to have sailed well off the deep end. How does that nice looking MF pull-type work for you Flusher? I suppose it may be possible that I am the only one who does well with a pull- type. This will be my last post on this thread, someone more knowledgeable than myself can go ahead and have the last word.
   / best disc harrow? #25
The reason why I "ignore" it is because I KNOW better......
One more time....Why do you suppose pull type disc's went obsolete and out of production more than half a century ago? Answer.....They just don't do as good of a job as several other better options, all things considered.
You didn't stike any nerve, so don't break your arm patting yourself on the back while making up your "facts" as you go along. It's quite simple really.... I just have an aversion to misleading, inaccurate, and/or false information being posted and represented as fact.
   / best disc harrow? #26
I'm going to put my 2 cents in here. Now I have about zero experience with tandem disks, but since the pull type tandem disk seems like they would be a pain to move around and not make a mess of the ground where you don't want to till, so transport is a problem. Disking in tight areas and or corners can be a problem. Thus hydraulic wheeled disk is invented to make transport much more convenient and not have as bad of a problem at corners. :confused:
Now as far as offset pull disks go, they work quite well, no ridges from turning, no problem transporting as long as your on the same piece of property. We have a 6' that needs some repair, an 8' and 12' that have been rebuilt and turn our ground quit well. No good reason for us to get wheeled transport disks, would serve no purpose for us.
   / best disc harrow? #27
Hopefully no one (well, only one person anyway) took my opinion wrong. Pull type disc's aren't a "bad thing" in and of themselves. My disagreement was with the opinion they're across the board BETTER than 3-point or wheel disc's. EVERYTHING has it's assets and liabilities. And there are dozens (hundreds?) of makes, models, and designs of each. There are good designs and bad designs of each type.
The reasoning I was given was largely based on the theory that 3-point disc's burn more fuel because of the tractor having a "hydraulic load". Also, I was told a pull type "pulls easier". Simply not the case. A disc of any description, with good blades, working at a given depth and a given number of blades will pull equally with another disc of same size/width/working depth/ect, type being irrelevent. A pull type disc of any description (ie tandem, offset, ect...) CAN be a good disc under limited circumstances. But they need to be in GOOD shape. Wher the lack of equality comes in to play is MOSTLY with transportability.
   / best disc harrow? #28
Wher the lack of equality comes in to play is MOSTLY with transportability.[/quote]
I have to agree 100%. Anybody that has a pull disk and has to transport it from one site to another is wasting time and energy in my opinion. There are more productive ways to spend your time, that's for sure.
   / best disc harrow? #29
I too have been looking for a 6' or 7' disk for my Kubota and have the same question as to what disk to buy. One question that I have that I didn't find an answer to is how much weight per disk is recommended? An earlier post mentioned his landpride disk - their model 2572 (6ft) carries 59lbs per disk, while their lighter and less expensive model 1572 carries only 34lbs per disk.
   / best disc harrow?
Obviously, I'm no expert here - or I wouldn't have asked the question initially, but someone said that weight of the unit should be 45lbs per disc or greater.
   / best disc harrow? #31
The most common in the old days when I was farming was an offset disc with hydraulic lowered wheels and hydraulic open and close.
Bruce
   / best disc harrow? #32
This post has been dead for a while, I wonder if the original poster found a disc?
   / best disc harrow? #33
I have seen The Leinbach Line before, but when I went to their website it redirects me to Everything Attachments. They sell their own equipment as well as King Kutter. Is Leinbach sold as KK?
   / best disc harrow? #34
I think Leinbach went out of business in the last year or two.
   / best disc harrow? #36
Nothing like finding a offset disc on the back lot of a Richie Brothers Auction. I gave $2500 for this Amco 9 footer. I then rebuilt it and painted it. I love it's weight. Weight is the key.
hugs, Brandi
2-8-13 Luke with 8.5 Foot Offset Disc.jpg4-1-13 Four New Disc Shoes.jpg4-6-13 Luke and Disc in Dirt.jpg
   / best disc harrow? #37
Nice work -- and you didn't get any paint on your shirt!
   / best disc harrow? #38
   / best disc harrow? #39
Yup. Closed up a week or 2 before I called trying to find a down pressure kit for my Leinbach PHD. Last fall if I remember.
   / best disc harrow? #40
hugs, Brandi
View attachment 413368View attachment 413367View attachment 413366
Looks good Brandi :thumbsup: I have been looking for the 6' version of that disc for a while. Had one of these in the 1970's and it was a great disc. Looks the same as your disc with the heavy spools between blades and heavy angle iron frame. We moved up in tractor size and bought larger implements to match. Now I am looking for the smaller stuff again that can be transported more easily. Make sure you keep that disc, it is a good one.
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
(139) PALLET OF UNUSED SAFETY CONES (A60432)
(139) PALLET OF...
FORKLIFT (A56857)
FORKLIFT (A56857)
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2004 Ford F-150 Ext. Cab Pickup Truck (A59230)
2004 Ford F-150...
