Hay King Pasture Renovator
   / Hay King Pasture Renovator
I believe she's sold. If for some reason the deal doesn't go thru, I'll PM you. It is supposed to be picked up in about 3 weeks.
Thanks for asking...Kyle
   / Hay King Pasture Renovator #22
Hi Warhammar,
I put a deposit down on it last week, and intend to run out to central Texas in the next week or two to pick it up.
Ed
   / Hay King Pasture Renovator #23
I have an Aerway, it's my business. (Pasture Aeration)
It's pretty **** cool, esp out here where it's just solid hard pack clay.
Goes as deep as the compaction lets it. (first pass can be as little as 2", but come back 90 days later and it's down to 5" and another 90 days and it's down to the full 8")
it's not a straight tine, it twists as it pulls so it "shatters" the ground, but it's perfectly fine for putting animals back on it.
I talked with the factory a while.
7 PTO HP per foot of Aerway,
DO NOT ADD extra weight, he said you'll break the frame, it's designed to take the weight it has on it. I have the water fill option (so i can truck it around) and full up, the 5' model weighs like 1800lbs.
It needs some front weight to run right, it's a little front end light when it's full up, even with the FEL. You can' tturn with it in the ground.
It does amazing things for the soil though.
Oh, things are outrageously expensive. a 5' is about 4 to 5 grand. 8' pull type is about 7 grand.
works great when overseeding too.
Here in Minnesota we have pretty darn good farm land but you never see these things being used in the hay fields. They run the stand around 5 years give or take and plow it under and put something else in to rest the soil. I am not an expert on this and this is just my observation. How much could you extend the life of the stand by using one of these machines?
   / Hay King Pasture Renovator #24
Your comments on Minnesota use might be comparing 'apples' to 'oranges'. The effect renovation might have is highly Dependant on many complicated and often misunderstood factors. Here in the south, there is considerable movement toward 'greener' ways of handling Mother Earth. Years of misuse has left much of the soil in a 'compromised' condition, and renovation is one of the many ways proven successful in restoring a balance to the system Mother Nature used for thousands of years.
i.e. - It may or may not work for you, but it does work for many people trying to use the 'less is more' approach.
I'm a firm believer in that anything you do to aerate the soils and help your land absorb more rainfall is a good thing.
   / Hay King Pasture Renovator #26
I got the renovator from Kyle this weekend. ....It was a pleasure to meet such a gracious person, and a joy to get a good solid piece of equipment.
I tried the renovator out on the worst strip through the hay pasture during what we here in Louisiana would call a drought. It was dry enough that it only cut four to five inches most of the time, and in some places actually 'chattered' a bit as I pulled it along in fourth gear. ....It seemed to work just fine, and I can't wait to do the whole pasture this fall when the moisture levels are ideal.
....It will be interesting to see if the strip I did this week shows any signs of improvement for the rest of the season, once the rains begin. .....I'll keep everyone updated.
Ed
   / Hay King Pasture Renovator #27
There are many things I do not claim to understand about farming. Some use no till methods while others don't and i can't explain why.
I'm not saying they don't work as advertized. I just saying that I have not seen any in use.
We try to do things the green way up here to.
   / Hay King Pasture Renovator #28
It has been a month now since I renovated the 3 acre strip that was very weak in the hay pastures.
....I am really impressed with the results !
...There isn't a noticeable difference in growth through the pasture now,,, but we have had almost perfect rainfall for the past couple of weeks.
I am convinced that a thorough renovation of the entire 22 acres this October will make very significant differences in the performance and quality in my hay pastures.
....More when available!!
Thanks for posting, I've seen all the rain you guys have been getting. It has rained within a few miles of here but NOTHING HERE...:mad:
I'm sure it should green up fine now that you've got some rain.
Take care, Kyle
ASSET DESCRIPTIONS & CONDITION (A52576)
ASSET DESCRIPTIONS...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Electric Concrete Mixer (A51573)
Electric Concrete...
2017 AUTOCAR YARD SPOTTER / TRACTOR (A52576)
2017 AUTOCAR YARD...
2025 New/Unused Wolverine Point Quick Hitch (A51573)
2025 New/Unused...
