Rotary Cutter Bush hog made by International World Agritech Co.??
/ Bush hog made by International World Agritech Co.?? #22
Hmmm...not to hijack this thread....but I have a situation on that top link that has me wondering too. I hooked up my new KK rotarty cutter to my Harbor Freight Quick Hitch, which left me with a remaining top link supplied by KK. Is this supposed to be used for something...or just an excess part for me? I "assumed" it was excess...but most times I "Assume".......(you know the rest of the story).
The below photos show the link with my cutter and the second photo shows tractor hooked to my box blade...similar to the way I was hooked to my cutter. :confused:
Note the beautiful paint supplied by KK. ;)
Since no one else responded. I think in the first picture the 'c' shaped piece is attached to the top link and allows the mower back to articulate up without putting pressure on the top link - the welded piece( which bolts where you apparently are attaching your top link) keeps it from floating down when you lift it or go over a rise. Often I back up a hill or rise and the mower moves /rotates up without binding the top link against the tractor. - Does this make sense? I have this on my world ag 7 ft.
/ Bush hog made by International World Agritech Co.?? #23
Actually, here is their web site. Not much to it.
They have the parts you need for your International equipment.
No great deals as far as I can tell.
DN Equipment
/ Bush hog made by International World Agritech Co.?? #24
Slippy,
Sorry I did not get back to you. I was on a long raid. We got one, one ran away, and two weren't there. :mad:
Well, they don't produce much equipment, mostly supply parts at wholesale/manufacturer level, they are not a retail business really. They do some sub contracting manufacturing for Woods I think. Like you said, the good thing is that they can provide parts for IWA items.
IWA made lots of stuff, I have four implements including a real nice hook/plow thing. Quality will vary due to the character of the old IWA owner. He would buy bulk parts from here or there so the component from China would break and the same component made in the USA would not, depends when your item was built.
/ Bush hog made by International World Agritech Co.?? #25
My son bought a used 6' brush hog made by this company thinking it was by International Harvester. Do you have a phone number where I can speak with someone about blades and bolts? Thank you
/ Bush hog made by International World Agritech Co.?? #26
There is a post by a member named "new2MFfrank" in a thread titled "Pictures of you on your tractor" in the Owning/Operating forum. Looks like he just purchased one of these new, he may be able to give you some info if you were to PM him.
Mark
/ Bush hog made by International World Agritech Co.?? #27
/ Bush hog made by International World Agritech Co.?? #28
Well, no offense sir. But their contact information has been listed several times throughout this thread. Try this: http://www.tractorbynet.com/forums/...g-made-international-world-2.html#post1591320 or this About Us
//greg//
Thanks Greg,
I hadn't taken the time to read through the thread. I was pretty sad going into this thing because all of the local tractor people were telling me that my son had bought a lemon and I had the feeling the company was gone and so were our chances of finding parts. I called them and they are terrific!! We will have new blades and bolts soon and will commence cutting the world one field at a time!!
/ Bush hog made by International World Agritech Co.?? #29
International Technologies has been purchased by Hawkline who is owned by Carry-on trailers. They are manufacturing new cutters and implements identical to the older Internationals.
/ Bush hog made by International World Agritech Co.?? #30
Blades and bolts are shelf items at Tractor Supply.
/ Bush hog made by International World Agritech Co.?? #31
i have a 5ft. international world agritech bush hog. for about 7 years we have work it hard with no problems it has been the best and toughest bush hog we ever owned.i just broke one of the blades off.got on internet found out they have went out of business i found new blades and new bolts for blades at a co. called temco here in southern ohio. they keep them in stock.the new blades are a lot more heavy duty than the ones that came on it.they told me that orginal when they broke it was where they bolted on replacement blades have alot more metal where they bolt on.here was a older man there that told me that they were heavyer and they would hit harder cut a lot better.the price was $29.99 each for blades and $10.99 each for the bolt,washer.nut.i think that was a really good price.
/ Bush hog made by International World Agritech Co.?? #32
Thanks for the up date. Do you know if they carry gasket kits for the gear boxes? One of mine has a leak. Not sure where it is comming from. Also, do you have a phone number for this place so I could call? Thanks!
/ Bush hog made by International World Agritech Co.?? #33
There are only two seals (not gaskets). If it's dripping from the top, you've simply overfilled it. If it's dirty down the front, it's the input shaft seal. If it's dirty around the base - or dripping on the ground underneath - it's the output shaft seal.
Another problem with that transmission is the unvented fill plug. When used hard, the expanding air from the heated gear oil has no place to go. So it pushes past one or both seals. The solution is a vented fill plug. That was my problem, so I ended up with an output shaft seal that I don't need.
If I can still find it, you can have it for a fiver.
//greg//
/ Bush hog made by International World Agritech Co.?? #34
My boxes do have a vented plug. There is oil around the base of the box and mower deck. Can you get me their number to see if they have the seals please? Thanks!
/ Bush hog made by International World Agritech Co.?? #35
Same seal, input or output. It's a 40x54x7, click here. Part number on mine is 15810. You can have both of mine for a tenner, and $3 for postage.
//greg//
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2021 FORD E-350 16FT BOX TRUCK (A59905)
2021 FORD E-350...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61306)
2023 Kubota...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
