I need to bury a gutter drain under a sidewalk
   / I need to bury a gutter drain under a sidewalk #21
So does the sweeper nozzle on a water hose if you have good city water pressure.
   / I need to bury a gutter drain under a sidewalk #22
Using a pressure washer can get you real dirty pretty quick. :D... But it works great!
Cut a hole in a piece of plywood to stick the pressure washer wand through, and use that as a "shield" from the blow back.
jp
   / I need to bury a gutter drain under a sidewalk #23
jp
Yea that would work:D
   / I need to bury a gutter drain under a sidewalk #24
I think imho if you use a pressue washer or any type of water you are going to be asking for a settling and cracked sidewalk before long. I think I would take up the offer for the wax job for the drilling. zman
   / I need to bury a gutter drain under a sidewalk #25
1*I think I would take up the offer for the wax job for the drilling. zman
I secont that.
   / I need to bury a gutter drain under a sidewalk #27
My downspouts are 3inch and they go into 4inch flex pipe.
I have the "4-inch flex pipe" under my walks, and 4-inches isn't going to make the walk settle or crack...Especially with "rebar" in it.
When using a pressure washer just try and keep the tunnel straight, and keep it as narrow as possible...Also try not to go to deep... If you do you can put sand underneath the pipe.:D
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2014 VOLVO A40G OFF ROAD DUMP TRUCK (A60429)
2014 VOLVO A40G...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
