I need to bury a gutter drain under a sidewalk
   / I need to bury a gutter drain under a sidewalk #21
So does the sweeper nozzle on a water hose if you have good city water pressure.
   / I need to bury a gutter drain under a sidewalk #22
Using a pressure washer can get you real dirty pretty quick. :D... But it works great!
Cut a hole in a piece of plywood to stick the pressure washer wand through, and use that as a "shield" from the blow back.
jp
   / I need to bury a gutter drain under a sidewalk #23
jp
Yea that would work:D
   / I need to bury a gutter drain under a sidewalk #24
I think imho if you use a pressue washer or any type of water you are going to be asking for a settling and cracked sidewalk before long. I think I would take up the offer for the wax job for the drilling. zman
   / I need to bury a gutter drain under a sidewalk #25
1*I think I would take up the offer for the wax job for the drilling. zman
I secont that.
   / I need to bury a gutter drain under a sidewalk #27
My downspouts are 3inch and they go into 4inch flex pipe.
I have the "4-inch flex pipe" under my walks, and 4-inches isn't going to make the walk settle or crack...Especially with "rebar" in it.
When using a pressure washer just try and keep the tunnel straight, and keep it as narrow as possible...Also try not to go to deep... If you do you can put sand underneath the pipe.:D
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
