TC45D 16LA and Bradco 509
   / TC45D 16LA and Bradco 509 #1
skinnr
Just picked up a TC45D with a 16LA loader and a new Bradco 509 backhoe. The rear transmission is trashed since the case has been broken on one of the webs that carries the PTO shaft. I paid $5000 for the whole package knowing that I will have to put some $$$ to get it back up and running. Should I even try to fix it or should I just part it ?
   / TC45D 16LA and Bradco 509 #2
All depends on how good you are mechanically. Do you have the skill, tooling, shop, etc, to split this tractor and change the rear housing. It being a hydro may be more costly. It's a thread here where a gentleman needs a hydro shaft but NH will only sell him the complete hydro transmission. That tractor in good shape in my area would sell for around $20,000 in this economy, maybe more. If you part it out the backhoe would bring around $4500 to $5000. The front end loader would sell for around $4000. Someone who wanted a different configuration of tires/wheels would probably give you $1500 or so. You can recover the money you spent easily. All depends if you want a few thousand now, or a good tractor later.
Jinman.........what say you?
   / TC45D 16LA and Bradco 509 #4
I'll pay him $5001 for it and he can pocket a profit.;)
Yes, I think he can easily recoup his investment by fixing or parting out the tractor. The tractor is probably worth lots more as parts than as an assembled unit.
I guess the thing is trying to find the right buyer for the parts and the fact that I would like to have a good tractor. I don't need the backhoe so that has been the plan from the begining. I have it in the shop with most of it broke down to confim the broken case. It looks like the only special tooling I might need is a press to remove some bearings and put the new ones in the new case. Unless I am mistaken it looks like as soon as you pop out a few bearing caps everything should start to slide out. Keep the advice coming and you never know jinman I might take you up on the $5001.
   / TC45D 16LA and Bradco 509 #7
So what have you done with your project. thinking about the backhoe.
Thanks Greg
   / TC45D 16LA and Bradco 509 #8
I would also be curious on what RickB has to say.
I think if it were close to me and I heard about it first, skinnr would have nothing to ask about.
Despite anything you hear or read from a dealer or manufacturer perspective, a 509 is way more hoe than a Class III chassis needs to have hanging off it.
I'd probably part it out, but without seeing it I can't say for sure.
Sorry it took so long to get back. The project is well under way. The major work is done now its just a lot of small parts that were missing that I am trying to track down. I will post some recent pictures. As for the backhoe I am torn on weather to keep it or not. I have an excavator sitting right next to it so it is hard to justify having another hoe. As for too much backhoe Rick B I will disagree. With the frame mount it is well distributed. Local dealer said that a PTO shaft was to long and that is how the case got broken.
   / TC45D 16LA and Bradco 509 #10
Makes one wonder why a 14-17 k tractor, 3k loader, and a 8k backhoe would go for 5k with a cracked rear casting. The backhoe and mount used is easily worth 5k. I'm sure a repair shop could fix it for four grand or less if they found a used casting. For an owner to sell this cheap just doesn't make any sense.
FORD 8770 TRACTOR (A51247)
FORD 8770 TRACTOR...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
5 Piece Combo Kit 20V Lithium-Ion Drill/Fan/Batteries (A51573)
5 Piece Combo Kit...
7pc Mini Excavator Attachment Set (A51573)
7pc Mini Excavator...
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
