Trailer tongue weight regulations
   / Trailer tongue weight regulations #31
To make sure each individual tire isn't overloaded.
Ding ding ding, we have a winner. If you pull thru a weigh station, the duals will likely be weighed as a pair. Get too close to the limits and each would be checked for overloading. The trailer tires we have are rated at 1820, per times 4. That covers the 7000 lb trailer rating. The truck runs tires rated at 2680 per, times 6. That covers the 11400 for it. I'd have to foul up the loading to get near the ratings but I normally get weighed before a trip to make sure.
   / Trailer tongue weight regulations #32
How do you get more weight one of the tires in a set of duals?
   / Trailer tongue weight regulations #34
Different tire pressures, run one at 80psi and one at 65psi and the 80psi one will be carrying more weight.
Aaron Z
Also by having more load on one side of the truck/trailer. Outer wheel would have more on loaded side and less on the light side.
   / Trailer tongue weight regulations #35
Or more tire wear in a pair of duals, making one tire smaller in diameter. I think that is a common wear pattern.
   / Trailer tongue weight regulations #36
Outer tires wear more than the inner ones. Worst tire on mine go to the rear outsides because the next step for them is the scrap pile.:(
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
2015 Jeep Wrangler Unlimited Sport 4x4 SUV (A51694)
2015 Jeep Wrangler...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
(4) 55 Gallon Drums of Bonderite (A51573)
(4) 55 Gallon...
