Trailer tongue weight regulations
   / Trailer tongue weight regulations #31
To make sure each individual tire isn't overloaded.
Ding ding ding, we have a winner. If you pull thru a weigh station, the duals will likely be weighed as a pair. Get too close to the limits and each would be checked for overloading. The trailer tires we have are rated at 1820, per times 4. That covers the 7000 lb trailer rating. The truck runs tires rated at 2680 per, times 6. That covers the 11400 for it. I'd have to foul up the loading to get near the ratings but I normally get weighed before a trip to make sure.
   / Trailer tongue weight regulations #32
How do you get more weight one of the tires in a set of duals?
   / Trailer tongue weight regulations #34
Different tire pressures, run one at 80psi and one at 65psi and the 80psi one will be carrying more weight.
Aaron Z
Also by having more load on one side of the truck/trailer. Outer wheel would have more on loaded side and less on the light side.
   / Trailer tongue weight regulations #35
Or more tire wear in a pair of duals, making one tire smaller in diameter. I think that is a common wear pattern.
   / Trailer tongue weight regulations #36
Outer tires wear more than the inner ones. Worst tire on mine go to the rear outsides because the next step for them is the scrap pile.:(
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2014 Ford F-550 4x4 Bucket Truck, VIN # 1FDUF5HT7EEB28740 (A51572)
2014 Ford F-550...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
JLG 1255 Telehandler (A53472)
JLG 1255...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
