Trailer tongue weight regulations
   / Trailer tongue weight regulations #31
To make sure each individual tire isn't overloaded.
Ding ding ding, we have a winner. If you pull thru a weigh station, the duals will likely be weighed as a pair. Get too close to the limits and each would be checked for overloading. The trailer tires we have are rated at 1820, per times 4. That covers the 7000 lb trailer rating. The truck runs tires rated at 2680 per, times 6. That covers the 11400 for it. I'd have to foul up the loading to get near the ratings but I normally get weighed before a trip to make sure.
   / Trailer tongue weight regulations #32
How do you get more weight one of the tires in a set of duals?
   / Trailer tongue weight regulations #34
Different tire pressures, run one at 80psi and one at 65psi and the 80psi one will be carrying more weight.
Aaron Z
Also by having more load on one side of the truck/trailer. Outer wheel would have more on loaded side and less on the light side.
   / Trailer tongue weight regulations #35
Or more tire wear in a pair of duals, making one tire smaller in diameter. I think that is a common wear pattern.
   / Trailer tongue weight regulations #36
Outer tires wear more than the inner ones. Worst tire on mine go to the rear outsides because the next step for them is the scrap pile.:(
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A51248)
UNUSED RAYTREE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
