Figurin rear axle ratio in Ford F150
   / Figurin rear axle ratio in Ford F150
Thanks everybody. That means my GCVW is higher than I thought it was.
rimshot
   / Figurin rear axle ratio in Ford F150 #12
That's a good thing. Living in Michigan with all the snow you get you really should spec a Limited Slip or Locking diff for your next truck.
Chris
   / Figurin rear axle ratio in Ford F150 #13
Any idea what that costs nowadays?
Last work I had done was in 2000. It was about $250 for labor to change gears or carrier. Back then, an average limited slip was about $250 too. Lockers/posi's were more, some much much more... I see now days a ring/pinion is running $150-$250
I had changed my old F250 4x from 3.55 to 4.11.
Chris
   / Figurin rear axle ratio in Ford F150 #14
I can not tell you. I did look at Eaton G80 lockers for my Fords Diesels but was turned off when I saw how it worked. I will only buy electric or air lockers. If you really want a locker check out Detroit Lockers. I have them on a Nissan Titan and love them. If you just want to put in a Limited Slip check the junk yards. With Ford selling so many trucks a few have to end up there.
Chris
   / Figurin rear axle ratio in Ford F150 #15
I "think" I could change my gears without changing the differential. I'm fine with the limited slip I have. Just wondering per axle for ring/pinion and labor.
If I got to where I needed lockers, I'd get another Jeep. Probably a flat fender :D
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A52472)
2021 ALLMAND BROS...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
2013 FOREST RIVER (A52472)
2013 FOREST RIVER...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
