Figurin rear axle ratio in Ford F150
   / Figurin rear axle ratio in Ford F150
Thanks everybody. That means my GCVW is higher than I thought it was.
rimshot
   / Figurin rear axle ratio in Ford F150 #12
That's a good thing. Living in Michigan with all the snow you get you really should spec a Limited Slip or Locking diff for your next truck.
Chris
   / Figurin rear axle ratio in Ford F150 #13
Any idea what that costs nowadays?
Last work I had done was in 2000. It was about $250 for labor to change gears or carrier. Back then, an average limited slip was about $250 too. Lockers/posi's were more, some much much more... I see now days a ring/pinion is running $150-$250
I had changed my old F250 4x from 3.55 to 4.11.
Chris
   / Figurin rear axle ratio in Ford F150 #14
I can not tell you. I did look at Eaton G80 lockers for my Fords Diesels but was turned off when I saw how it worked. I will only buy electric or air lockers. If you really want a locker check out Detroit Lockers. I have them on a Nissan Titan and love them. If you just want to put in a Limited Slip check the junk yards. With Ford selling so many trucks a few have to end up there.
Chris
   / Figurin rear axle ratio in Ford F150 #15
I "think" I could change my gears without changing the differential. I'm fine with the limited slip I have. Just wondering per axle for ring/pinion and labor.
If I got to where I needed lockers, I'd get another Jeep. Probably a flat fender :D
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2021 Acura RDX SUV (A50324)
2021 Acura RDX SUV...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A52748)
2018 Rock Solid...
