7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not?
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #21
Are you talking intake manifold, or air-filter housing, and tubes that feed air to the turbo?
QUOTE]
Specifically, the air filter and the tube that connects the air filter to the turbo. The stock Ford airbox leaked and there was a silent recall on them. For a diesel, I would not advise using foam filters; too much maintenance keeping 'em clean and oiled, plus too many horror stories of dirt getting past them and ruining turbos. A good pleated paper filter works great. The Tymar is a tube made for the 7.3 and uses a huge Donaldson 6637 pleated paper element.
The 7.3's connect from the exhaust manifold to the turbo inlet collector with a set of up-pipes. There are some high-dollar upgrades available there too...as well as bigger intake manifolds. For most of us, the cost/benefit ratio rules out goodies like that. And of course, there are goodies like upgraded turbos...and head studs...and pistons...the sky is the limit.
I've heard of 7.3's yielding over 800 hp on the dyno. There's even a common rail conversion being developed by at least one vendor. I'd say within a year or so we'll see the 7.3 break the magical 1000 hp mark. (My personal target is 400 hp, I'm only $900 short right now...)
For us mere mortals, I'd recommend the air intake, downpipe, and chip. For any diesel, I'd strongly recommend a EGT (pyro) gauge, mounted pre-turbo. A boost gauge is nice (measures the turbo's performance) but isn't critical IMHO.
The problem is that once you get past the 600HP mark, the 7.3 is likely to scatter. It won't hold up to extremes like a 5.9L, a Duramax, a 6.4L or even a 6 leaker.
The problem is it isn't "hard" enough. it has a weaker bedplate than newer diesels.
Buddy of mine built 3 or 4 of them and learned the expensive way that they just can't hold the power once it gets that high without serious expense. I would think you'd need to start thinking about a girdle or some other kinds of structural upgrades.
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #22
QUOTE]
I highly doubt you'll see a 1000 hp 7.3, their specs have a hard time handling even the load that 500 hp puts on their internals. Then when you add in the fact that because of the popularity of the 6.0, because of it's better performance even with as bad of an engine as it is, and the fact that the 7.3's popularity with hot rodders continues to diminish, the ability to find any kind of real good high performance parts for it is very small. The 7.3 is a good engine in stock form, but when you start modding it you quickly run into the limit of it's design. You also have to look at the previous DieselPower Challenges from the last 4 years. While yes, 7.3 do enter, there never able to hang with the newer 6.0's, D-max's, or 5.9's.
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #23
Try 823 hp on spray, you really need to get out more. :)
638 fuel 823 on N20 - Powerstroke Nation
edit: Lemme explain a little about this "the 7.3 internals can't handle 500 hp" myth. The real difficulty lies in the HEUI injectors and their IDM driver. The injectors can't respond quick enough to flow massive amoutns of fuel at high RPM. Since they can't rev up high, the only way to deliver massive HP was to produce more torque at lower RPM. There's a big torque requirement in delivering 800 hp at 2800 RPM versus 800 hp at 4000 RPM.
The tuners now have been able to partially break some of the RPM limitations, plus they have smoothed out the power delivery so it doesn't bash stuff to pieces. Up to 500 hp is easy without major engine mods, the head studs and head gaskets are the weak link then, but I can't address life in the 600 hp region....my wallet only goes to 400 or perhaps 450.
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #25
Lets be honest if you need that kind of power you should buy a semi. If you are just wanting to burn the track up get a race car. If you want to pull the sled out the back buy 2 engines and build one till it breaks and back off just a little on the second one.
I have not seen a 1 ton truck with a big enough rearend to handle 600hp diesel HP little own with a trailer on it? Most of the high numbers you are talking about are for a 15sec pull down the track. I do like seeing these, but they don't help the OP unless he is wanting to set land speed record pulling his camper.
That being said said I have over tuned a old 444 7.3L with out a turbo on gas and had to pick up the crank of the road. It sounds more fun than it was. They all can be blown apart if you don't know what your doing.
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #26
DMAX & 5.9L Cummins are already both over 1,000 HP. No 7.3L or other Ford diesel for that matter that I'm aware of, have made it even close to that. :p
Maybe the Taco will finally get them there??;) Everyone knows the 7.3L powersmoke, the 6leaker and the 6.4 flamethrower can't do it. :p:D
Um, I think this thread has wondered WAY off course.
I'm looking to tow a camper, not compete in truck and tractor pulls, or drag race.
If I could get the Cummins in the Ford Super Duty, that is the way I'd go. I'm not impressed with either the Dodge or Gov't Motors trucks (both have goo d engines). The Fords seem to be the best overall package. If I'm buying a < 150k mile truck (I've decided to stay under 150k) then the differences between a 500k mile engine, and a 300k mile engine doesn't matter. The ability to hot-rod the engine to 1000 ft*lb is cool and all, but I don't need it. The stock 7.3L intercooled Powerstroke is just fine for me. I do know to avoid the 6.0.
Speaking of the 6.0L, did they ever resolve the problem? I found a decent deal on an '06 F-350 Crew cab. That is the 3rd full year for the 6.0L -- did they get it right by then?
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #28
Per Ford, the 2006 6.0 PSD engine has had the least warranty claims of any engine in a Ford that year. After my Dodge started getting old I debated about getting an older 7.3 PSD or a later model 6.0 PSD. I ended up buying an 2006 F350 with the 6.0 PSD in it and I've been very impressed with it. To stay in your target range and for your mentioned needs, I think you'd be happy with a '99 to '02 7.3 PSD. There are more of them out there to pick from than from Dodge or GM since more were sold. That gives you better odds of finding the right truck for your needs. Good luck!
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #29
Why avoid the 6.0? I have 2 and they are the great. I have never owned a Cummins but have had a 7.3, these 2 6.0's, and a Dmax and both of mine have been trouble free and by far the best diesels I have owned. They are very powerful and easy and cheap to upgrade to not only add Hp but improve the fuel consumption. And yes, you are right about Ford having the best overall package.
The issues with the 6.0 was solved by early 2004 build date trucks. Late 04's and there after should be fine but you can get a lemon on anything. My 04 has had zero issues with the entire truck. My 06 has only had a bad fuel gauge and the dash cluster needed changed.
Chris
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #30
I thought the same; I had Ford's before(F250 4x4's), albeit gas engines. They were great trucks, especially my '89. Sold it with 225k on it; that 351 ran like a top still.
My Dodge has been great. I still like the Ford's and would consider one if I were shopping. But, my Dodge has been great, as has the Cummins.
I personally, would not get GM, mostly because I like a straight axle truck suspension in a 3/4 ton or heavier truck. The motor/tranny is probably great, the interior is probably nice. But I do use 4wd, hunting ect. That low slung GM IFS just, well, aint the same. But, I also grew up in solid axle Jeeps too...
I would look at the truck that fits you best. Stock, the "Big-3" are pretty evenly matched.
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #31
You're right. My apologies for getting off topic.
It wasn't a singular "problem". It was many problems. So many problems in fact, it caused the demise of Ford & IH's 25 yr partnership forever-lawsuits, etc.. The problems may have been resolved, but the next problem was perception. Deserved or not, much of the GP percieves the 6leaker as a t_rd. The first 2 years of problems destroyed the 6L's reputation. Then the problem becomes that is it lowers resale value and limits the appeal to potential buyers (except to the Ford guys who think there's nothing wrong with the 6L or those who don't know any better). The other issue is the 6L was lower on HP/TQ than the competition, but that's not an issue to you. So if resale value and a bad perception of the 6L and lower HP/TQ doesn't bother you and you can get a good deal, go for it.
I was a died in the wool Ford guy like drago and d---pilot in late '06 when I was buying a new truck and the GM & Dodge were better trucks at that time. That's why I gave a GM a try. I'm pleased with my decision.
Good luck with the 6L or 7.3L!!! :D
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #32
I am a biased owner of a Cummins 5.9 in a 2001.5 Dodge 2500.
I would go for the Cummins.
Straight 6 has many advantages over a V8 config, not to mention you can actually see and service the 5.9.
I think the trucks themselves are a tossup, with the Ford having a slight edge in all but the manual tranny department. If you are so inclined the NV5600 6 speed available in the Dodge may be the best manual tranny every put behind an engine in a pickup. Check it over carefully, some of these trannys have not been treated kindly, it is recommended to overfill the lube by a quart or so to ensure complete lubrication. Also the NV5600 is fussy about its lubrication requirements. Parts are expensive and getting hard to find for the NV5600 so that is something to consider.
I will add that the 2001.5 Dodge was the first non-Ford truck that I have ever owned. Bought if for the engine and the engine has been great. I come from a long line of Ford truck owners and took quite a bit of razzing from my Dad and other relatives about the Dodge, until they drove it. It is turned up to around 350hp/850 torque at the rear wheels, pulls very well and can deliver an honest 22-23 mpg on the highway at speeds less than 70 mph.
Dave
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #33
I think the original poster has received quite a few replies specific to his question about 7.3L PSD engines and 5.9L Cummins engines. You seem to be the only person telling him that he has to be like you and buy a GM product or he will get junk. The picture is pretty clear.
I think you only read what you want to see and fail to give an accurate portrayal of what I really said. I advised him of problems I encountered with the 7.3L and well known problems with the 6L. I also recommended to him to be open minded and look at Dodge & GM. I don't think being myopic and only recommending Ford everytime makes any sense:
Builder said:
Whether it's Ford or Dodge, you're going to get a great deal. I would also keep an eye out for a newer Ford V-10
I believe those are pretty strong recommendations from me to buy Ford as well. Maybe you didn't bother to read them? :confused:
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #34
Yep, my apologies also for getting off course. (By the way, the shop that got the horsepower numbers I referenced isn't too far from me; I've been there, bought parts from them and am scheduling a dyno run with them...so I have gotten out!!!)
As others have said though, really any of the Big 3 trucks are quite good. They all perform quite well and by the same token they all have a few minor weak points. If somebody gave me a new Dodge or new GM, I sure wouldn't turn it down.
I'm going to see the '06 tomorrow. I'll keep you all posted.
I did more research, and it looks like the 6.0L issues where resolved by the end of '04. The 6.0L has 50HP more than the 7.3L -- what's not to like :D
Also, starting in '05, Ford changed the front suspension to give it a 5' smaller turning circle, and added the integrated brake controller. So, it looks like this truck has a couple of features that I won't get with the 7.3L trucks.
And, yes, I like hot rodding too, I just won't be doing it with this truck. There was a post on TBN recently from a garden tractor puller getting 100 HP out of a Kubota D1105 (same engine that is in my B7610, 24 HP stock). I think that is very cool -- but I won't be doing that to my B7610 either :)
I am very impressed by the HP & Torque numbers that can be gotten out of the Cummins, and if I could get the Cummins in the Ford truck, that is what I'd buy.
I have two nephews that are Ford service techs (for a local Ford dealer), one of which is their diesel specialist, so besides my preference for Ford, this also gives me two great resources if problems should arise.
I do appreciate all the input, and will update you all when I get a truck. :D:D
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #36
I have a 04 and a 06, one with the old front suspension and one with the new. The new style give a much better ride. As for the brake controller just be aware it was a option. I have it on my 06 and its by far the best controller out there.
Chris
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #37
If by "Camper" you mean something that will go only to camp sites that have hard paving everywhere, then MAYBE you don't need 4WD.
If there is even a slight chance that you will have to tow on wet grass up a slight grade, at LEAST get one with a limited slip rear axle - BOTH is better, but I regard limited slip rear as a MUST HAVE.
Same with towing your tractor around, if you will only ever be on hard road surfaces you won't NEED 4WD, but that might limit you to loading/unloading at roadside.
Chris
The one that I'm looking at has the brake controller (it is in the pictures of the dash). I'm actually leaving in a few minutes to go look at it in person.
Jay
Many of the camp sites we go to have dirt and/or gravel roads, and some have some grades that might be tough in 2WD if it is wet. For towing the tractor, it would always be paved roads -- as you stated, I can unload curbside.
   / 7.3L Powerstroke or 5.9L Cummins with over 200k miles -- still lots of life, or not? #40
FWIW, I helped a buddy with concrete today. He has a F350, guessing about a 2001 or thereabouts. 7.3...
He bought i used with a little over 100k miles. I drove it today. It has 285k miles on it now. Drivers seat was about wore out, but otherwise it seemed to be good. Body was good for a concrete guy... Ran good. I towed a concrete buggy around. A lot of the miles he has put on it has been hauling concrete tools, a Bobcat in a dump trailer ect.
He had some issue with the auto tranny linkage, but that is about it. Not the tranny, but the linkage itself.
He is not easy on hos rigs. He takes care of them, but he also uses them...
I towed the concrete buggy with that truck, and a Bobcat on a trailer with mine. I prefer the power band on my Dodge-Cummins, but the 7.3Powerstroke towed nice for the short distance I drove.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2017 Har-Tru CourtPac Tennis Court Roller (A59228)
2017 Har-Tru...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
