whitedogone
Gold Member
Excellent, I think I would fall into the second catagory of inspector.
BTW whitedogone, I caught a break this week with my foundation inspection. We have two building inspectors in our part of the county, one a twenty something that's known to be "a challenge" and the other a semi retired builder with 30 yrs experience. Luck of the draw I got the old man. Happy Days. He laid out the whole inspection cycle with milestones in a way I understood and can follow in 10 minutes.
There will be an expansion joint attached to the foundation walls where the pad butts but no fixed anchors, so it's probably correct to say the pad floats inside the walls. Most garages here are monolitic slabs and they work fine, I decided to go with a separate foundation with knee walls because it's more forgiving to grade to on the side of this hill and it matches my existing garage. BTW Eddie, your observation on the entry door rattled in my head till, as you can see by the photo, I bumped it to a 3'0". I'll thank you many times in the days ahead, but right now I'm still muttering.![]()
Pretty temperate here so no need to insulate under the slab. Plan to use a vapor barrier with wire, not much faith in fiber added to the mix. Many moons ago we used regular visqueen but time has proven that a poor choice. I plan to use a 10-15 mill product made for the task.
