Need small diameter grease gun head OR longer fitting
   / Need small diameter grease gun head OR longer fitting #11
I've a fitting somewhere that goes onto a regular grease gun. It's used to lube fittings on universal joints that are too small for a regular gun tip to go onto. Don't know whether they make them any more.
Ralph
   / Need small diameter grease gun head OR longer fitting #12
There is times when the wind do blow in Southern Alberta!:D
I spent several years down there and it blew the hair right off'n my head.:eek:
Sometimes it even moves the big round bales.:D
I forgot about the round bale thing and I cut hay. I once saw an aerial photo from Alberta that showed the tracks make by round bales after a major storm. You could see where they rolled for a great distance--maybe miles? Would be a great photo for this site.
   / Need small diameter grease gun head OR longer fitting #14
Actually I posted photos of that several years ago.It was down near Medicine Hat I believe. Looked for the pictures today but could not remember where I stored them.:D:D
Did a quick search:
http://imgur.com/MGMa5.jpg
Did a quick search:
That is the exact photo and one of the reasons I jointed this site. Great photo.
I once got behind an Airstream travel-trailer convoy on it's way to Medicine Hat. Seemed like thousands of them and I couldn't pass no matter how hard I tried. I know the backside of an Airstream real well.
   / Need small diameter grease gun head OR longer fitting #16
1/8 pipe nipple and a coupling brought one of mine out to where I could at least see it .
Thanks for the ideas. the pipe and coupling ideaa will work and the websites offer similar longer grease fittngs that will work as well. I happened to stumble into a well-stocked hardware store and found longer grease fittings as a commonly stocked item in the bins. It's just a real long grese fitting but will work just fine.
Probably not a common item everywhere but at least they are out there if one looks hard enough.
J and L Cargo Express Shadowmaster Enclosed Trailer (A56438)
J and L Cargo...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
