B&S Kickback While Starting
   / B&S Kickback While Starting #1
dave1949
Super Star Member
nowhere, md
Hanomag
I have a 2 yr old Sears rototiller with a B&S 850 model engine. It has developed a bad kickback while pulling the started rope. Snaps the pull handle out my hand and leaves fingers stinging.
The engine has had several very fast/hard stalls from hitting rocks while tilling.
Should I expect to find a partially sheared key on the flywheel causing the ignition timing to be off?
Thanks, Dave.
   / B&S Kickback While Starting #2
My thought would be absolutely yes. A partially or fully sheared pin is surely what you will find.
Many years ago I bought a cheap 5.5 horse Tecumseh engine for a small riding mower. When I went to start it for the first time, it jerked the pull rope out of my hand and proceeded to completely destroy the start ratchet. I was baffled and called up the shop where I bought the engine. They got a good laugh out of my calling because that engine was designed for a rotary mower where the blade is flywheel mass. I had a small pulley bolted to the crankshaft and that wasn't enough.:rolleyes::eek: Of course, that's not your problem. If your engine just developed the kickback, it has to be the shearpin causing timing to be early.
Thanks Jinman,
It's been about 30 yrs since I did any serious small engine work, was afraid I might find a whole new world when I went looking :eek: It never used to kickback, I think it began about the same time as my rock tilling episodes. It would be a crime against machinery to put a decent tiller on my garden :D
It's on my winter to do list. Cleaned up and tilled the garden yesterday, it snowed a bit this morning. Way too early for that.
Dave.
   / B&S Kickback While Starting #6
Reminds me of the old 22HP Jonson and Evenrude outboards.
If the manual spark was not at the correct position and you pulled real snappy like with a good grip, you could end up in the drink! (or loose some fingers)
Hyster H225E (A47384)
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
New Holland C185 (A47477)
New Holland C185...
NEW Thiessen Track Closer Disk (A55218)
NEW Thiessen Track...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
