B&S Kickback While Starting
   / B&S Kickback While Starting #1
dave1949
Super Star Member
nowhere, md
Hanomag
I have a 2 yr old Sears rototiller with a B&S 850 model engine. It has developed a bad kickback while pulling the started rope. Snaps the pull handle out my hand and leaves fingers stinging.
The engine has had several very fast/hard stalls from hitting rocks while tilling.
Should I expect to find a partially sheared key on the flywheel causing the ignition timing to be off?
Thanks, Dave.
   / B&S Kickback While Starting #2
My thought would be absolutely yes. A partially or fully sheared pin is surely what you will find.
Many years ago I bought a cheap 5.5 horse Tecumseh engine for a small riding mower. When I went to start it for the first time, it jerked the pull rope out of my hand and proceeded to completely destroy the start ratchet. I was baffled and called up the shop where I bought the engine. They got a good laugh out of my calling because that engine was designed for a rotary mower where the blade is flywheel mass. I had a small pulley bolted to the crankshaft and that wasn't enough.:rolleyes::eek: Of course, that's not your problem. If your engine just developed the kickback, it has to be the shearpin causing timing to be early.
Thanks Jinman,
It's been about 30 yrs since I did any serious small engine work, was afraid I might find a whole new world when I went looking :eek: It never used to kickback, I think it began about the same time as my rock tilling episodes. It would be a crime against machinery to put a decent tiller on my garden :D
It's on my winter to do list. Cleaned up and tilled the garden yesterday, it snowed a bit this morning. Way too early for that.
Dave.
   / B&S Kickback While Starting #6
Reminds me of the old 22HP Jonson and Evenrude outboards.
If the manual spark was not at the correct position and you pulled real snappy like with a good grip, you could end up in the drink! (or loose some fingers)
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
New/Unused Spirit Electric Tricycle (A57453)
New/Unused Spirit...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Toro Groundsmaster 400-D (A57453)
Toro Groundsmaster...
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
