Suggestions;need to cut down 1/4" thick steel support
   / Suggestions;need to cut down 1/4" thick steel support #21
I think that if z0lt3c had the tools to cut the extra off, he would not have asked for some guidance.
   / Suggestions;need to cut down 1/4" thick steel support #22
yup that is the way I understood it, a zillion ways to do it but if you don't have the tools........you should work on having friends with the same interests....chances are they will have the tools
I live so far out in the boonies...I have them all
except for the ones that got burned up in my barn fire:(:(:(
I am working on replacing them:D:D:D:D:D
   / Suggestions;need to cut down 1/4" thick steel support #23
Do you have a sawzall? With a metal cutting blade it would take about 2 minutes. Then clean up the cut edge with a file or grinder.
TWO MINUTES!?!? maybee if your doing it by hand with a hacksaw!
a good metal cutting sawzall will cut through that in under a min. Ive done it.
a 4.5" grinder with cut off disc (expect to use it up)
a 14" metal chop saw
a gas axe
a bandsaw with metal blade
Well despite all the encouragement to DIY, I stopped by the lawn mower shop down the street today and sure enough they had a torch and grinder.
Picking up the finished pieces tomorrow at lunch. An angle grinder probably would have been cheaper ;)
Machine shop charged me $40 to cut these down.
As it turns out, I'm not even sure I needed them cut as I found a different better arm position to use in the end. However, it does look pretty all trimmed off;
   / Suggestions;need to cut down 1/4" thick steel support #27
Yikes
It looks like they have indeed been chewed off! Anyone at the machine shop ........thpeak with a whithle????
For that price you could have had them chromed and polished here in Northern Michigan!!!!!
   / Suggestions;need to cut down 1/4" thick steel support #28
Looking at the top link mount, is that the heavy duty one? My dealer suggested the heavy duty upper link mount for a 3 point hitch backhoe. The one for the b7500 looks like an l- shape that bolts to the seat mount bolts and the pto cover bolts and the 4 bolts your upper link uses. Page 6 of this link (pdf) seems to indicate a heavy duty top link for the b7800.
http://www.dot.state.mn.us/equipment/contracts/tr_cpt_utl/40a.pdf
I didn't know they made an HD top link bracket for the B7800, but thank you very much for pointing that out. I assume mine is not HD.
I guess I will head over to the Kubota dealer tomorrow and see how much they want for one that will fit the B7800.
Thanks,
   / Suggestions;need to cut down 1/4" thick steel support #30
Next time:
Do you have an ordinary electric jig saw? You can get metal cutting blades for a couple of dollars at Lowes or Home Depot and they will cut 1/4 inch thick, no problem, works quite well in fact.
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
HIGH-END MINI GOLF CART (A53843)
HIGH-END MINI GOLF...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
