Meyer Snowplow adapted to QA?
   / Meyer Snowplow adapted to QA? #31
Builder my friend you made a good point on the rams but there better off under the frame than on top of it. I've had lumps of hard snow come over the top of the blade that would have taken those rams out if they were on the top of the blade frame. Have a look at the first picture. Yep, rear skids ;) Last winter I also added side Super Nova LED strobe lights to the system so when I'm backed into a driveway and my blade is out in the road vehicles can see the blade much easier. It's nice to see some of you like my design :D It might not be the design that fits everyones needs but it sure works for me.
You've put way more thought into your plow than mine. Your's is a work of art, mine is just something I threw together. I bought a $400 meyers plow and a $120 mount plate then welded mounts and a hook to it. Yours is much more customized and you did a great job. Believe me, I'd rather have yours, but for the small amount of plowing I do these days, mine works fine. I am mounting skids on my mounting plate this fall and that's all I really want to put into mine.
4shorts said:
Oh and as for the relif valve. I've got 13 years with that plow on the front of a 1993 GMC truck and one year with it on the front of the Kubota and when I've hit something side on it worked the exact same way which makes me that the hyd's on the tractor has something there to make the pressure by-pass if It needs to. I can only report on how it worked for me last winter and I'm more than pleased with the set up.
That's what I thought, too, but don't tell Duffster that. :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::) I have a bypass relief valve sitting in my shop I could use, don't know if it's really worth the time.......
   / Meyer Snowplow adapted to QA? #32
Duffster is right about the fact that there's no relief valve in those rams. I've had them apart many times and there just a regular cylinder inside. I do think that my system has some sort of by-pass in it because if I hit something the blade will give and you'll notice the cylinder move in slightly.
I try and put as much though into things I do and I hate having to do things over the second time. It's cheaper to do it right the first time if possible. I use my system commercially so I don't want trouble in the middle of a storm and not get a lot cleared for my customer. Having it look pretty, well that's just a bonus :D Sometimes the only difference in a good looking plow and a great looking one is a flick of paint :D
   / Meyer Snowplow adapted to QA? #33
4shorts.. Just watched the video. (aren't Iphones great). I would love to soo it in the daylight. Also, if you have a blower on the back, why the blade on the front?
Wedge
   / Meyer Snowplow adapted to QA? #34
Wedge
Wedge. I was going to do a video in the daylight but every time I went out plowing my wife was in the house and I leave early to do my plowing so I didn't get her out with the camera. I'll be doing one this year for sure so stay tuned :D
As for the blade and the blower. I do a few government lots. One of the lots got a fenced compound where they store confiscated vehicles and boats. At one time I would have to try and plow the snow out of the compound with the blade on the truck but with the blower on the back I can blow it all over the fence with little work. Other than that and a few driveways I hardly use the blower. The blower would be to slow for me to do all the snow removal with.
With the quick change system I can drop my plow and pick up my bucket and carry the snow from the upper portion of the lot and carry it down to the lower part of the lot which I get extra pay doing so this set up of mine suites my needs perfectly.
   / Meyer Snowplow adapted to QA? #35
Maybe you two oughta get a room together swap plow stories and compare meyers plow cylinders??? :D ;):eek:
:D j/k couldn't resist. You said the same thing about me!
You got me! Chalk one up for builder. ;)
You missed the punch line though. There were all sorts of piston rod-------- Well you get the idea. See I can laugh at myself.:rolleyes:
Chris
   / Meyer Snowplow adapted to QA? #36
I paid $80. each up here in Newfoundland last winter. Keep an eye on the bolt holes when buying them. I've seen them with differant sizes and you might not notice it until you go to install them.
Thanks. I ordered some off the net for about that. Around here they want $187.50 per cylinder. I guess the guy with the plow shop thinks no one can use the internet to get anything.
Chris
   / Meyer Snowplow adapted to QA? #37
Chris
I know what you mean. I live on an island and see the same thing here but like you I use the net for a lot of my shopping. I just restored an old Honda CT70 and purchased 95% of the items for it off the net. If I had to buy it around here it would have cost me fours times the amount. Gotta love the net :D
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
2024 Schulte 5026 Batwing Rotary Cutter (A55315)
2024 Schulte 5026...
202476 (A54757)
202476 (A54757)
