BX23 Joystick
   / BX23 Joystick #1
Couple of Achers
Gold Member
3rd rock from the sun
L4740
For you BX23 owners out there, I have a question regarding the float position. I realize on most tractors that have the float position feature when you push the joy stick up into the float position, it "detents" and stays there until you physically pull it out of that position. On my BX23, it has the float position and it works fine as long as you "hold" the joy stick in that position. However, it will not "detent" into that position. It never has since new. I wasn't sure if that is normal on the 23 or not. Thanks.
   / BX23 Joystick #4
Mine goes into the detent position and will stay there, but I usually hold it as it tends to bounce out of position while I am plowing snow. It would be nice if it could be locked into position.
   / BX23 Joystick
Ken_CT, I'm glad you replied. I definitely wanted to here from a BX23 owner. It's predecessor the BX22 had a completely different valve on it and did detent. One of the big changes with the 23 was the new joystick. So I didn't know for sure if it was by design, or if there is something goofy with mine. Sounds like it may be the latter. I think I'll run down to the dealer tomorrow and talk with the service manager down there to see what he has to say. Thanks for know.
   / BX23 Joystick #6
Ever since it was new, my BX23 has jumped out of the float position. It would sometimes stay there for a while, but especially over bumpy ground, it woukd jump out. If I'm going to float the loader, I now hold the joystick in the float position.
   / BX23 Joystick #7
x2 same here
   / BX23 Joystick #8
That doesn't seem normal. Mine stays in float without jumping out unless I really bounce over something, in that case the float is the least of my concerns.:D
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2017 Chevrolet Tahoe, 179,380 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2017 Chevrolet...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
2014 Dodge Charger Passenger Car (A59231)
2014 Dodge Charger...
