B series Alternator Upgrade...
   / B series Alternator Upgrade...
Glad you found the problem
With the prints it would be easier to help you trouble shoot the problem other wise we are guessing.
tom
Prints? Do you mean pictures? And, no in this case they would not helped.
An old pro told me to never overlook the obvious
I would not have looked there as it was original wiring wasn't it?
Regards
DGS
Correct it was NEW kubota wiring harness w/ shrink wrap on the terminal connector...
I was about to go Hari Kari on the trractor and kubota when I gave one last effort on checking things over...
   / B series Alternator Upgrade... #23
wow! a simple wiring issue. I would have gone nuts too. I am you actually found the problem and its pretty simple thing. I am just surprised that you replaced the alt 3 times and not the wiring or what that ifo left out too ?
Anyway, congrats on getting it fixed. Perhaps a nice letter to kubota who made the wiring would be in order :D . you might get a free hat or something out of of it ;) .
   / B series Alternator Upgrade... #24
Slightly off the original topic but... ;)
I have an older b7100 that has a really wimpy dynamo. I notice that this alternator mounts approximately where I have a belt tensioner mounted on my tractor. Assuming you could fab a bracket to provide tension and that an alternator would fit... it there any reason to NOT take off the old belt tensioner and put an alternator in its place?
   / B series Alternator Upgrade... #25
I've been thinking of doing this to my 7100 also. Anyone tried this?
Its not the Alternator that is the issue...Its the wiring harness.
The dyno has a separate rectifier/regulator (under the dash on the 7510) the Ant has is own built in regulator, and there is a new replacement relay that gets installed... Part of the old wire harness, get abandoned.
It can be done..Escavader did his own, but I think he wished he had just bought the kit...
Have you checked with your dealer? You need to go thru sales or service dept for a kit from Kubots whole goods department.....
The new alternator is great, worth the $180 and the aggrevation, now thats its working!! rear work lights, new front lights, strobe...probably a 12v heater once my enclosure is built!! Pictures to follow!!!
   / B series Alternator Upgrade... #27
no mine WAS the kit.Igot it through the dealerMy problem was a faulty fuse that showed continuity and juice would pass through[until it wiggled]After a long headache the service guy from KUBOTA and i stumbled on it by wiggling the wire harness while he kept his tester on the battery.We both had checked the fuse ,it tested out fine.When you took it out and shook it it rattled.Makes me wonder who the clowns are that make up these kits.
alan
   / B series Alternator Upgrade... #28
Is the alternator supplied in the kit, the same Hitachi unit that others are getting from other sources? Does it have the internal regulator? Are there any markings on the unit?
Good thing you caught the problem. Probing the B+ terminal of the alternator would have caught it right away... should have full battery voltage all the time.
Yes the alternator is in the kit...
Its a DENSO alternator
16241-64012
   / B series Alternator Upgrade... #30
I was referring (and I'm sure Charlz is too) to an upgrade to a B7100 to replace the dynamo. Thanks for your help.
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
CATERPILLAR ARTICULATED WATER TRUCK (A60429)
CATERPILLAR...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2011 Toro Multi Pro 1250 Sprayer Cart (A59228)
2011 Toro Multi...
CATERPILLAR 305 CR EXCAVATOR (A60429)
CATERPILLAR 305 CR...
