Firefighter Kubota
Glad you found the problem
With the prints it would be easier to help you trouble shoot the problem other wise we are guessing.
tom
Prints? Do you mean pictures? And, no in this case they would not helped.
tom
An old pro told me to never overlook the obvious
I would not have looked there as it was original wiring wasn't it?
Regards
DGS
Slightly off the original topic but...
I have an older b7100 that has a really wimpy dynamo. I notice that this alternator mounts approximately where I have a belt tensioner mounted on my tractor. Assuming you could fab a bracket to provide tension and that an alternator would fit... it there any reason to NOT take off the old belt tensioner and put an alternator in its place?
Its not the Alternator that is the issue...Its the wiring harness.
The dyno has a separate rectifier/regulator (under the dash on the 7510) the Ant has is own built in regulator, and there is a new replacement relay that gets installed... Part of the old wire harness, get abandoned.
It can be done..Escavader did his own, but I think he wished he had just bought the kit...
no mine WAS the kit.Igot it through the dealerMy problem was a faulty fuse that showed continuity and juice would pass through[until it wiggled]After a long headache the service guy from KUBOTA and i stumbled on it by wiggling the wire harness while he kept his tester on the battery.We both had checked the fuse ,it tested out fine.When you took it out and shook it it rattled.Makes me wonder who the clowns are that make up these kits.
alan
Is the alternator supplied in the kit, the same Hitachi unit that others are getting from other sources? Does it have the internal regulator? Are there any markings on the unit?
Good thing you caught the problem. Probing the B+ terminal of the alternator would have caught it right away... should have full battery voltage all the time.
I'm going to stick to the whole 7 Amps or so from the Dynamo :-(
The small gray dynamo, that comes on most of these tractors, is rated at 15 amps. To get this, the engine would need to be above idle speed.
WOW, is that all the dynamo puts out for power?
Wonder what Kubota was thinking when they put this thing on these tractors.
I looked at the 7510 before I bought my 2350, and I remember that dynamo under the hood, and wondered then what were they thinking.
I was looking at adding an alternator to my B6100. The Kubota supplied Denso would work well. It is very close to fitting in place of the idler. Problem is the side panel and possibly a bit of the hood would have to be bumped out (cut/welded/etc). Only needs about an inch more :-( So for now, I'm going to stick to the whole 7 Amps or so from the Dynamo :-(
As I understand it, my B3030 puts out 14.5 amps via the dyno. What other advantages, besides more lights, can there be by switching to the 40 amp alternator? Will exisitng systems work better, for example? etc. thnx
