How big of a cylinder
   / How big of a cylinder #12
"I'm not familiar with the term "cylinder centerline". Explain please."
I mean an imaginary line through the center of the hydraulic cylinder assembly going the long way. Also this is the action direction of the cylinder force. Here is a crude sketch.
   / How big of a cylinder #13
Here are some pics I took of a HD woods blade with full hydraulics.
   / How big of a cylinder #14
So the minimum distance to the pivot point would be measuring perpindictular to that line passing through the pivot point?
   / How big of a cylinder #16
That's right.
Thanks, that helps me follow the formulas and torque applied. I can see how the length of the ram and the angle at which the ram attaches between the frame and blade can also have an effect.
Thanks for all the replys and realy good info.I will use a 4" single clyinder. For now this project is on hold because I just bought a front blade that has hyd lift and angle that I have to figure out how to mount and plumb. Thanks again.
Bill
   / How big of a cylinder #19
Bill
I have a Frontier RB2196H and it has the angle cylinder which is a 2-1/2 in bore x 12in stroke which gives me 40 degrees of angle both ways. Bull..........
   / How big of a cylinder #20
4 in cyl is a bit of over kill, but if they are that cheap, and you have the extra bucks, then go for it.
ROME AH-240 LOT IDENTIFIER 117 (A53084)
ROME AH-240 LOT...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
J BAR SD5 5' ROTARY MOWER (A51247)
J BAR SD5 5'...
UNUSED CFG MX15RX EXCAVATOR (A51247)
UNUSED CFG MX15RX...
