How big of a cylinder
   / How big of a cylinder #12
"I'm not familiar with the term "cylinder centerline". Explain please."
I mean an imaginary line through the center of the hydraulic cylinder assembly going the long way. Also this is the action direction of the cylinder force. Here is a crude sketch.
   / How big of a cylinder #13
Here are some pics I took of a HD woods blade with full hydraulics.
   / How big of a cylinder #14
So the minimum distance to the pivot point would be measuring perpindictular to that line passing through the pivot point?
   / How big of a cylinder #16
That's right.
Thanks, that helps me follow the formulas and torque applied. I can see how the length of the ram and the angle at which the ram attaches between the frame and blade can also have an effect.
Thanks for all the replys and realy good info.I will use a 4" single clyinder. For now this project is on hold because I just bought a front blade that has hyd lift and angle that I have to figure out how to mount and plumb. Thanks again.
Bill
   / How big of a cylinder #19
Bill
I have a Frontier RB2196H and it has the angle cylinder which is a 2-1/2 in bore x 12in stroke which gives me 40 degrees of angle both ways. Bull..........
   / How big of a cylinder #20
4 in cyl is a bit of over kill, but if they are that cheap, and you have the extra bucks, then go for it.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
