Kasco front blade
   / Kasco front blade #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I just bought a Kasco mfg. front mounted blade .It is new but 5 yrs old. The person I bought it from didn't have the instructions. I am pretty shure I have all the parts but am not shure how the mount for the front of the tractor should go together. If anyone has a Kasco front blade and could post a few pics it would be of great help. Or if you have instructions would be better. If not I will sit and stare at it awhile untill I think I have it figured out and put it together that way.
Bill
   / Kasco front blade #2
Kasco items are made in Shelbyville, IN if that helps any.
   / Kasco front blade
I did know that. I looked on their web site for info, but I think they no longer make the front blade and couldn't findany pics or info.
Bill
   / Kasco front blade #4
Bill
There is an email link for 'information' on the contact page of Kasco's website.
I'd be sending them a request for a setup manual or parts breakdown, or both.
   / Kasco front blade
I think I have every thing figured out. I have everything in place just not tightened up.I still have a little fabricating to do. I do have 1 extra piece but I think that is because this was bought for a cub and I am putting it on a Ford. This is a verry well designed blade. I do have 1 more question. The lift cyl has 2 pins on the upper mounting plate. If you remove the lower pin it allows the blade to float and still alows you to raise the blade. With both pins in you have the ability to use down pressure. The control valve that came with it doesn't have float. I am wondering if it would be easier to get a control valve with float so you wouldn't have to keep changing the pin.
Bill
   / Kasco front blade #6
Is this blade for snow? if so then you need float and rarely need down pressure, vice versa if the blade is for dirt.
Can't completely picture your set up, but if the plow will float when that pin is removed without the different/new valve, then run it like that for snow. If your doing dirt work then pin it and you'll have the down pressure. best of both worlds.
Get some pics, good luck
   / Kasco front blade #7
Bill
Does your loader come off to mount/use this blade? If so then why not use the valve you have?
Like JB, I am not fully seeing the big picture...some photos would help a lot.
   / Kasco front blade
Here are some pics. The 1st pic is of the lower brace that goes from the bottom of the mount back to the drawbar mount in the back. The second pic has both pins in locking it so you have down pressure. The 3rd and 4th are with the pin out allowing it to float. I did think about using my loader valve but it is mounted to the loader and is a PITA to remove the hoses. I also wanted to get away from the regen. I dont think the valve that came with the blade has it. ll I have left to do is hook up the hydraulics.
Bill
   / Kasco front blade #9
Excellent pictures, Now I understand that you FEL valve is attached to the loader and removed with it.
So, this blade came with a 2-spool valve? I would suggest a new joystick valve run your blade-and if your real ambitious you could make it work the loader and the blade and solve your regen problem forever.
   / Kasco front blade
Kenny, It came with a 2 spool 2 lever valve. I would like to use a 1 valve for everything like you suggested. Where would you put the quick disconects. There is not enough room at the valve. Maby put 2' hoses off the valve and then the QD's?
Bill
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2014 International Maxxforce DT (A53317)
2014 International...
Towable Centrifugal Water Pump (A59228)
Towable...
2016 Toro Groundsmaster 4500-D 4WD Commercial Rotary Mower (A59228)
2016 Toro...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
