Need Snow Plow For 3320 W/300 CX Loader
   / Need Snow Plow For 3320 W/300 CX Loader #11
I put this together from a 7 Meyers that I cut down to 67? The skin was rotted so I removed it, did my welding had it sand blasted and painted it. Then I bolted on a シ thick poly skin. I made an adapter that is bolted to the front of the tractor and uses 1 pin to connect it. I use the FEL to lift it and the bucket hydraulics for the swing cylinders. Takes about 2 minutes to hook it up and you don稚 need to remove the FEL to use it.
   / Need Snow Plow For 3320 W/300 CX Loader #12
Seems to me there would be visibility issues with the bucket and the plow both there? Like looking around a 4' plate of solid steel. I do like the simplicity of it.;)
Chris
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A52748)
PENDING SELLER...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
